A/C makes car almost stall sometimes
Old May 4, 2010 | 04:07 PM
  #121
silvermrnc's Avatar
When idling the tach drops a few hundred rpms when the a/c is on sometimes.
Old Aug 14, 2010 | 09:41 AM
  #122
D-VO's Avatar
Hey guys. I thought I'd share something with the community, and maybe figure out why this happened.
Firstly, I was one of the unfortunates to have the bolt on the A/C condenser fan to strip and fall off, then damage the condenser. So, what I did was have the fan welded to the fan motor. (The metal part) Now at this point my A/C had not been working for a little over a year, so when the car was stalling with the A/C on, I thought it could have been the many things I had changed during that year.
About four days ago the weld broke off, and left the fan chattering while the fan motor was running. So, I took the condenser fan off and put the car back together. Now WTH? The car no longer stalls while the A/C is on? Don't get me wrong though, the A/C works fine as long as I'm not in heavy traffic where the efficiency drops off, but why did this fix the problem? I'm not very electrically inclined, so all I know about the condenser fan is that is has two speeds and pulls a little load off the alternator while running. Could this be related to a grounding issue? Thoughts?
Thanks
Old Aug 14, 2010 | 10:31 AM
  #123
AbrasEvo's Avatar
I used to have the same problem, Mine turned out to be caused mainly by big cams, then I just started driving naked on hot days, seems to work.
3011carlos
Jul 18, 2013 02:50 PM
deadstockkpomp
Sep 24, 2012 06:49 AM
fabcas311
10
Jun 30, 2011 12:39 PM
Kracka
Oct 3, 2009 04:13 PM
fkw958
Feb 6, 2008 11:09 AM
