Evo Redline Raiser
Old Jun 25, 2005 | 10:59 PM
IDRINKV8's Avatar
lol no prob i guess i was pretty vague with the question i didnt know how to phrase it no because i know i had a bunch of 240's and they sound like pure **** after redline lol but turbo non turbo nissan mitsu big differences.
Old Jun 25, 2005 | 11:01 PM
vegasboy301's Avatar
Old Jun 25, 2005 | 11:05 PM
IDRINKV8's Avatar
time for sleep thanks for the help
Old Jun 25, 2005 | 11:09 PM
what a trooper...
goodnight
Old Jun 25, 2005 | 11:55 PM
RalliArtEvoVIII's Avatar
I think Evo can rev safely beyond 7500 up to about 7800 maybe
Old Jun 26, 2005 | 12:15 AM
Mr. Slappy's Avatar
Rev safely up to 8000... but I have problems with getting locked out of 2nd gear past 7500.
Old Jun 26, 2005 | 02:51 AM
CRVdrftR05's Avatar
How come when I put the needle past my CRV's redline my car starts to shake? lol Sorry if it's not on topic with EVO but I'm talking bout redlines soo...sorta on topic? Is the "factory sets are lower to cover for warranty" only for high-performance cars like the Evo or S2? Or all?
Old Jun 26, 2005 | 03:36 AM
Deca Auto's Avatar
Why go all the way to 8000 when people say its the same as shifting at 6000? Im talking about a stock evo, no aftermarket cams.
Old Jun 26, 2005 | 07:10 AM
honda-guy's Avatar
engines are design to make the most power at a certain rpm range (unless you have Vtec or similar apparatus). there's no point of raising the red line if you don't have to supporting mods to make power in the high rpm range. valve floating is the main concern when increasing red line with stock valve train. valve float can cause the valve to come in contact with each other or the pistons and then kaaboom. more of a problem with high compression NA engine with dome pistons. it's always a good idea to upgrade your valve springs and use titanium retainers to prevent valve floating. rod bolts is another conern with high rpm engine. they have to be strong enough to keep to rods and piston connected to the crank when the piston change direction from up to down during an intake stroke. there is a lot of g-force involve when the piston change direction.
Old Jun 26, 2005 | 09:05 AM
BMan's Avatar
Manufacturers set redline values for different reasons. Some will set the redline for driveline critical speed, some for lean-out condition, some for valvetrain stability, most of these things are easy to fix. Some mfgs use the redline to cheap out on pistons and rods and use sintered metal parts (cheaper than cast) so with a modified ecu, you will send a rod through the block (Ford 4.6L for example).
Old Jun 26, 2005 | 04:16 PM
CRVdrftR05's Avatar
Thanks Bman that helped. I'll just drive to 5kRPM from now on. lol
Old Jun 26, 2005 | 10:43 PM
termsheet's Avatar
My redline is set to 7800 but I get the same 2nd gear lockout problem much above 7000. The additional RPM range is really handy at the track. There are some corners where having the extra range allows me to shift in a better spot. It definitely doesn't feel like I'm making any more power in the higher RPMs.
Old Jun 27, 2005 | 08:10 AM
honda-guy's Avatar
you might have a worn out synchro, or try using a different tranny fluid.
Old Jun 27, 2005 | 08:39 AM
Kee1pride's Avatar
Good god! Punctuation please? I don't want to be a **** about this. I could care less about grammar and spelling but damn! I at least want to know where one thought ends and another begins.
Old Jun 27, 2005 | 11:04 PM
IDRINKV8's Avatar
I was tired, alright lol you know what i meant!!
honda-guy
26
Feb 17, 2014 08:10 PM
chasesyellowevo
Sep 12, 2012 05:53 PM
F1fan07
Jul 21, 2009 03:32 PM
Celica2EVO
Jan 30, 2008 08:16 AM
LancerEVOmann
12
May 20, 2005 09:56 AM
