cel light came on this morning
Old Aug 6, 2005 | 09:15 AM
navysevo's Avatar
this morning i took it out for a rip hit second gear and the car bucked like the rev limiter at 6500. then a minute later the cel light came on should i reset the ecu???and how would i do it?
i have many bolt ons and turbo trix dynoflash tune
Old Aug 6, 2005 | 09:21 AM
navysevo's Avatar
someone?
Old Aug 6, 2005 | 09:23 AM
Tech@SA573's Avatar
It doesn't sound like it's an important CEL, but it's normally free to find out what it is. You may as well take it in somewhere just in case. I don't know what kind of parts shops you have up in NJ, but I know a lot of the ones around here (i.e. Autozone) will at least tell you what it is for free.
Old Aug 6, 2005 | 09:26 AM
navysevo's Avatar
should i just reset the ecu?
Old Aug 6, 2005 | 09:28 AM
navysevo's Avatar
well the place around the block will tell me for free i guess ill just go there
Old Aug 6, 2005 | 09:30 AM
Tech@SA573's Avatar
Like I said, it would be a good idea to check it just in case. If you really don't want to take the 15 min. (driving time included) to check it out, then yeah, you may as well reset it. Like it said, probably not anything important...maybe just a misfire...you;d hafta get a response from some of the actual EVO guys around here.
Old Aug 6, 2005 | 09:37 AM
navysevo's Avatar
damn none of the tuner shop are answering there phones
i wish somebody would let me know
Old Aug 6, 2005 | 09:51 AM
SlowCar's Avatar
buy a code scanner / eraser for ~$70
Old Aug 6, 2005 | 10:08 AM
GOKOU's Avatar
Your question is pointless unless you know what the code is. Got autozone and find out what the code is .
Old Aug 6, 2005 | 10:20 AM
MitsuJoe's Avatar
It sounds like an overboosting cel. Do you have mods?
Old Aug 6, 2005 | 10:32 AM
4whlpl's Avatar
I'll put money on an overboost cel.
Old Aug 6, 2005 | 11:05 AM
navysevo's Avatar
you guys are right it was overboost cel P0234 had it erased
will this happen every time i turn up the boost even with race gas????
on pro b 2 just went from 55 to 56 and got cell on wot in 2nd
Old Aug 6, 2005 | 11:12 AM
MitsuJoe's Avatar
Yes it could. What are you turning up the boost to?
Old Aug 6, 2005 | 12:21 PM
navysevo's Avatar
peak is 21.5 at 55 setting i saw like 22 .5 with the 56 setting
Old Aug 6, 2005 | 02:22 PM
GOKOU's Avatar
Ask TT to verify that they took out the boost cut
