Max boost, on stock injectors ..etc.etc.
Old Aug 23, 2005 | 03:26 PM
eatonjb's Avatar
with just the adition of an intake and excaust, what is the most I can turn up the boost (with a boost controller) can the stock Evo MR handle?
20.3 at 3500, and 17 at 6500 is stock (according to Mitsu's website)
what can I turn it up to , without damaging the car.. on 93 or 94 Octain.
CAN I turn it up? if not, what do I need to upgrade to get more out of it.
e.b.
Old Aug 23, 2005 | 03:32 PM
djmikeymike's Avatar
im sorry man but you need to use the search
Old Aug 23, 2005 | 03:36 PM
eatonjb's Avatar
No Luck searching.. could be wrong keywords
Old Aug 23, 2005 | 03:49 PM
dsm95hybrid's Avatar
21-22psi on 93 octane, however get your fuel and timing optimized with a flash and buy a fuel pump. www.ttp-engineering.com has a nice set of ECU reflashes for the MR. I have hit 32.5psi on the stock turbo with a custom flash on stock injectors, no knock.
Old Aug 23, 2005 | 04:07 PM
Dan_EVO's Avatar
The turbo can't be efficent pass 26 psi(can it), why the hell would you want 32.5 psi.
Old Aug 23, 2005 | 04:12 PM
kmcconn9's Avatar
just run 20-21. anything higher that than without alky will result in reliability issues..
Old Aug 23, 2005 | 04:13 PM
kmcconn9's Avatar
but seriously, the search button does work wonders...just look into what others have accomplished with similar mods..
Viegasjuice
Oct 3, 2014 07:56 PM
heartagram88
14
Oct 5, 2009 11:45 AM
evogottago
Aug 15, 2008 12:51 PM
Derek888
32
Oct 18, 2004 01:22 PM
Luffy
Feb 23, 2004 02:14 PM
