View Poll Results: UP GRADING IGNITION SYSTEM
U only need a Larger diameter spark plugs wires it make the car runner smoother
0%
Get the whole ignition system that way it will make the car run smoother
50.00%
Don't get either because your running on stock boost and also your car is already running fine.
50.00%
Voters: 4. You may not vote on this poll
Just a quickie?
Old Sep 6, 2005 | 05:34 PM
lbcEVO8's Avatar
Just a quickie?
Just a quick question. I have an Evo VIII running 350 hp 340 tq. stock boost , tba, bov , intake, boost gauge. everything is running fine but what i was thinking was this. I used to have a honda civic and i added an aftermarket spark plugs to it and it ran much smoother on the throttle reponds and such. I believe it may have also had better ignition on the spark plugs. Anyways my question is this. For a turbo car such as my Evo with what i have done already and it runs fine if i got bigger spark plugs wires would it make my throttle responds smoother? and my idle smoother too? Or should i get the whole ignitions system? Is this all neccessary for what i've only modded? or just leave it alone it's fine the way it is because i won't feel a diffrents because i'm only running on stock boost.
Old Sep 6, 2005 | 05:42 PM
k270kmh's Avatar
If it is fine, why to touch?
Want something better... put ralliart spark plug wires.
Old Sep 6, 2005 | 07:21 PM
lanevokai's Avatar
is that something you preffer? how much of a size diffrents? stock vs rallie art?
