my evo is screwed IDEAS?
Old Dec 20, 2005 | 12:30 PM
navysevo's Avatar
well the car is at mitsubishi i know later what is goin on
Old Dec 20, 2005 | 03:37 PM
Evoryder's Avatar
update?
Old Dec 21, 2005 | 06:24 AM
navysevo's Avatar
well they looked at it and said the starter is bad....so its on order.. but the service manager said the mechanic said something didnt sound right, but they are going to wait till the starter is in and go from there...
Old Dec 21, 2005 | 06:51 AM
johnny's Avatar
Registered User
good luck! keep us updated, im curious as well
Old Dec 21, 2005 | 10:45 AM
nnorris7413's Avatar
Ok, i feel like an idiot. What's pop starting?
Old Dec 21, 2005 | 10:48 AM
Rallyman's Avatar
Question
Could be a leaking or blown head gasket - and one or more of your cylinders full of water. Remove all the plugs and see if the engine turns over then. If there is water in a cylinder it will spurt out.
You need to be careful not to bend a rod if this is the problem.
Old Dec 21, 2005 | 10:53 AM
AndyBandy's Avatar
pop-starting = getting the car moving and "popping" the clutch to try to make the momentum of the car will turn the wheels to work the engine in reverse cycle....but once you engage the clutch...disengage it again quickly
Old Dec 21, 2005 | 11:02 AM
smokedmustang's Avatar
I had a problem where it stalled, it was the fuseable link on the starter. removed the link and hard wired it. no problems. Any drivability issues? could you have locked up the Transfer case? could you have vibrations? need more info if you have it!
Old Dec 21, 2005 | 11:12 AM
04 evo's Avatar
This a joke?
Old Dec 21, 2005 | 11:16 AM
SterlingEvo's Avatar
Hopefully Mitsu takes care of everything! BTW, my car acted similar when my old exhaust rubbed the o2 sensor wires on the bottom of the car and shorted it. I had to have it towed. Funny story from that: The tow truck driver told me "you oughtta buy a Ford, them things run forever!"
Old Dec 21, 2005 | 11:17 AM
mrbkkt1's Avatar
actually, this problem does sound like hydrolock to me. starter would click because it is not strong enough to compress water. car would lock all wheels no matter what gear it is in. could also be a timing belt prob too, but classic symptoms of hydrolock is more likely.
Old Dec 21, 2005 | 11:25 AM
04 evo's Avatar
I get the whole water thing, BUT... He would have had to drive through a pond, or stick a garden hose in intake to get the amount of water needed to lock it up like that...
Old Dec 21, 2005 | 11:27 AM
Rallyman's Avatar
No, just a small leak in a Head Gasket into one cylinder would be quite sufficient to lock it up over night. If this is the case the water needs to be removed as soon as possible to avoid damage to the cylinder wall and piston rings.
Old Dec 21, 2005 | 11:30 AM
Mark Sebby's Avatar
Originally Posted by navysevo
ok well i tried to start it and nothing but click... charged the battery overnight and nothing tried to jump start it in the morning and same exact thing ..all i hear is the solonoid click and nothing. ok so i tried this i dont know if you can but i had a friend help me push and tried popping it and nothing but locked all 4 tires everytime. . . . so then a flatbed came and said he would screw up the front end if he tried and he proceeded to hook it up to give it a good pull so i can pop start it..well that didnt work no matter what the car just locked all 4 up ....does any one have any ideas???? on wtf could do this ???
Did you try using the other key that was provided to you at the point of sale?
Sometimes those transponder keys will give you that type of problem!
Thanks,
Old Dec 21, 2005 | 11:31 AM
04 evo's Avatar
So with a small leaking head gasket as you stated, don't you think that he would have noticed other problems before total overnight lock up? If it is a small leak like you stated.....
