my evo is screwed IDEAS?
Old Dec 21, 2005 | 11:33 AM
  #31
redninja's Avatar
I am having a similar problem right now. My car wont start either, it just stalled the other day while driving down the street. I have checked at much as I can, but nutthin. But nothing works. It at my mechanic now who will let me know what he finds.
Old Dec 21, 2005 | 12:09 PM
  #32
jbrown's Avatar
Originally Posted by zyounker
Couple things.. you don't push start a car in 4-5.. try it in 1st maybe 2nd
3rd.. check your grounds.. If it is clicking it is likely hooked up, but can't pull the amperage it needs..
If not, pull the starter off and have it tested.
Check the ground on the battery side as well as the wires going to the starter.
+1
Old Dec 23, 2005 | 09:30 AM
  #33
smokedmustang's Avatar
What ever came out of this?? any updates?
Old Dec 26, 2005 | 04:05 AM
  #34
WongFu's Avatar
hey i had this same problem its fuse on the bat. so i just bypassed it the dealership said it would be fine
Old Dec 26, 2005 | 06:27 AM
  #35
DamoEvo7's Avatar
definetly sounds like a starter to me mate.....and as said tryin to jump start a evo in 3-4th just wont work...2nd only!!
Old Dec 29, 2005 | 08:29 AM
  #36
Matz's Avatar
Fuses are safety mechanisms. If you blew a fuse, there's a good reason for it, and usually it will mean that you have a short in the car somewhere. If it's the battery fuse that blew, you definitely don't want to bypass it, as your short would be in the main battery line. I wouldn't want to see anyone short a circuit that has an 80A fuse on it. I would imagine that the result would be melted insulation at the least, or a fire in the worst case scenario.
If the solenoid clicked, then there is power. As the original poster already said, the dash lights, radio, etc. work fine. I would check all connections to the starter.
Old Dec 29, 2005 | 08:43 AM
  #37
hotrod2448's Avatar
An 80 amp short would be sufficient to weld some sh*t together.
Old Dec 29, 2005 | 08:55 AM
  #38
SteveosEvo's Avatar
any updates???
Old Apr 24, 2007 | 09:52 PM
  #39
djevoawhp's Avatar
any updates?
Old Apr 24, 2007 | 09:54 PM
  #40
djevoawhp's Avatar
im having the same problem.. turned the crank on my car by hand and it spins freely, new starter, new plugs,new battery, all it does is click when i turn it over.. wont turn over at all just clicks
any ideas??????
Old Apr 25, 2007 | 10:36 AM
  #41
InsaneEvolution's Avatar
IF you push start a car and the drive wheels lock up when the clutch is popped,you have a seized motor.Especially when the starter wont turn the motor and the car is only 2-4 yrs old.
(Opps didnt see how old the first post was)
Old Apr 25, 2007 | 11:52 AM
  #42
TylerO@WORKS's Avatar
Check the connections to the starter, trace them back to the harness and battery, make sure there is good continuity and no cuts or shorts...
And did you check all the fuses and fuseable links?
Old Apr 25, 2007 | 02:10 PM
  #43
djevoawhp's Avatar
will check today... any other options????
Old Apr 25, 2007 | 08:00 PM
  #44
djevoawhp's Avatar
fuses are good... anything else????????
