stock blow off valve question
Old Jan 11, 2006 | 07:39 PM
03venom's Avatar
I am reverting back to the stock BOV and I had a question… the top of the valve with the small tapered inlet seems to be removable (at least from my BOV… see pictures). Is this normal? Can I reinstall it, or has it given up the ghost? For reference, when I put the tapered end into the BOV (long end down) it seems relatively loose. Any ideas???
Attached Thumbnails stock blow off valve question-bov2.jpg   stock blow off valve question-bov1.jpg
Old Jan 11, 2006 | 07:41 PM
eling99's Avatar
ive never seen that inlet thing...unless its 03/04 thing'
just install it without that thing!!!
Old Jan 11, 2006 | 07:45 PM
Warrtalon's Avatar
What the hell is that thing? That's not part of the stock BOV. You should have two large openings just like it shows in the pic. The one on top goes to the IC pipe and the one on the side goes to the MAF pipe opening.
Old Jan 11, 2006 | 07:56 PM
03venom's Avatar
You guys are great!!… I inherited the BOV from the previous owner and I now realize he included some superfluous parts in the box. Thank you SOOO much!
Old Jan 12, 2006 | 12:45 AM
Jakeg97's Avatar
iv never seen that strange piece before.....
Old Jan 12, 2006 | 12:47 AM
Jakeg97's Avatar
the mismatched color looked suspicious
Old Jan 12, 2006 | 04:40 AM
honda-guy's Avatar
that small piece that you tried to put inside the BOV is an inline filter. you put it on the vac line before the BOV, it keep dirt from entering the BOV diaphram.
Old Jan 12, 2006 | 10:26 AM
8urv8's Avatar
I just took the stock BOV of my O4 when install some new intake pipes and a new BOV, and I never saw a piece like that.
Old Jan 12, 2006 | 11:03 AM
purplegodzilla's Avatar
looks kind of like a vacuum filter...
Old Jan 12, 2006 | 11:05 AM
IMR-TIM's Avatar
looks like the exact filter that came with my HKS SSQ
Def not part of the stock BOV......ditch it
Old Jan 12, 2006 | 12:59 PM
GgreyEVOIX's Avatar
The stock valve is not a bov nor does it VTA, it's a BPV.
Old Aug 22, 2006 | 02:39 PM
machron1's Avatar
Ummmmmmm all blow-off valves are compressor bypass valves...and all compressor bypass valves can "blow off" if you don't plumb them back into the intake...so it's all semantics. You can recirculate the HKS Super Sequential Blow Off Valve...does that mean it's not a BOV anymore?
Old Aug 22, 2006 | 06:44 PM
DanJ's Avatar
plastic?
Old Aug 23, 2006 | 04:13 AM
4TUN8's Avatar
Thank you Mr. "Pot leaf in my avatar" guy. You knew exactly which part he was talking about when he said "stock bov" though didn't you?
Yeah, you did.
Old Aug 23, 2006 | 04:44 AM
Mekanic's Avatar
Yeah, you did.
