bad day
Old Jan 15, 2006 | 07:59 PM
J!n K@z@mA's Avatar
bad day
i was workin on my wheels 2day, and my rear wheel, right side, lug nut cross threaded itself. i try to properly align it a couple of times b4 going 4 it and next thing u know, it got stuck. i cant even remove the nut. . now i need to go to dealership to have them fix it. hopefully they won't kill me on my pocket which they always do
Old Jan 15, 2006 | 08:01 PM
lookEVO's Avatar
do it yourself, way cheaper, just go buy a lug. and pound the old one out
Old Jan 15, 2006 | 08:06 PM
lilman8403's Avatar
i agree. don't let the dealer always win!!
Good luck
Old Jan 15, 2006 | 08:28 PM
little's Avatar
Your in a little bit of a tough spot. I've had this hapen in the past. I ended up fixing it myself by first braking it off.
How I did it...
Get a braker bar with a "cheeter" piece of pipe that will fit over the braker bar to make it longer. With enough leverage you will be able to brake the stud off. But now you will need to replace the stud. I'm not sure what this requires on an evo.
Old Jan 15, 2006 | 09:30 PM
Ultimate CC's Avatar
If you have the time and patience do it yourself as it will save you some money and its not to hard of a job
Old Jan 15, 2006 | 09:50 PM
hel_if_ino's Avatar
https://www.evolutionm.net/forums/sh...ad.php?t=93155
Old Jan 15, 2006 | 09:56 PM
J!n K@z@mA's Avatar
i really don't need it but thanx anyways
Old Jan 15, 2006 | 10:42 PM
hel_if_ino's Avatar
What are you talking about?? Why did you even create this thread? For people to feel sorry for you, this guy in the link went through the same thing you did, and he explains exactly how to fix it, I was just trying to help you out.
Old Jan 16, 2006 | 04:47 AM
J!n K@z@mA's Avatar
i'm here just to vent out. and if u noticed i have so much respect to u for doing the search for me for that link and thank u for that. if u feel offended, my apologies
Old Jan 16, 2006 | 01:23 PM
Juiced's Avatar
i had this happen to be one once on an old car.
The way i did it was to remove the axel nut and pull ou the whole hub assembly with the wheel and just use a cutoff tool to but the back portion of the stud then pulled it out with the lug nut. then since it's off it will bew easy to place a new stud in anyways.
Old Jan 16, 2006 | 03:06 PM
Greg K's Avatar
cleaned out all the crap relating to the fake warrtalon.
