MR diaqueen multigear oil question??
Old Mar 20, 2006 | 03:16 PM
jrsimon27's Avatar
hi friends i want to know if the MR diaqueen multigear oil they sell in evomoto can be use in a 2005 evo 8 RS ?? i have sent emails to evomoto.com but not getting an answer back??
Old Mar 20, 2006 | 03:23 PM
jrsimon27's Avatar
anyone??
Old Mar 20, 2006 | 03:28 PM
hondafan's Avatar
you should yes. the only difference is that it's a little thinner, it's 75-85 instead of 75-90.
Old Mar 20, 2006 | 04:08 PM
jrsimon27's Avatar
ok but i thought it was SAE GL5 90??
Old Mar 20, 2006 | 06:07 PM
jrsimon27's Avatar
anyone else??????
Old Mar 20, 2006 | 07:14 PM
Spec'd's Avatar
The LSD diaqueen is what Mitsubishi recommends for your transfer case
and rear differential. 75W -90. For your RS.
This is different from the MR 6 speed transmission diaqueen super multi gear oil. 75W -85. Not for your RS.
They both are GL5 but with different viscosities.
Basically what hondafan stated is correct.
For your 5 speed transmission on the RS you want to use some type of GL4.
Old Mar 20, 2006 | 08:13 PM
hondafan's Avatar
diaqueen gear oil GL-4 75-90 is for 5-speed trannies, diaqueen super multi gear is GL-4 75-85 for 6-speed trannies(or 5-speed from my research), diaqueen LSD oil GL-5 SAE90 is for all evos' transfer cases and rears. the super multi gear is just a super expensive crappy tranny fluid that mitsu made special for the MR, i use an exact equivilent GL-4 75-85 synthetic instead.
rydogg008
May 23, 2016 03:27 PM
EvolutionRacing
Jan 11, 2016 12:35 AM
evo_skillz
Aug 4, 2008 06:01 PM
Thoe99
Oct 20, 2007 08:01 PM
EvoMoto
14
Jan 12, 2006 06:00 PM
