Which replacement clutch is closest to stock feel?
Old May 24, 2006 | 07:20 AM
AC556k's Avatar
I want to upgrade my clutch but want it to feel close to stock. No drag racing and will have under 350HP. Also the least expensive the better. Any suggestions?
Thanks
Old May 24, 2006 | 07:24 AM
Sleeper2G's Avatar
Center Force Dual Friction is just like stock and not too expensive.
Anarchy99's Avatar
ACT-HDSS is as close as your going to get. You woun't be able to tell it's in there.
Old May 24, 2006 | 07:25 AM
Ev0ikon's Avatar
ACT street.
Old May 24, 2006 | 07:40 AM
fsugatorbait's Avatar
How much is it?
Old May 24, 2006 | 07:51 AM
ruchc03's Avatar
if you've got a synchro grind... get that shnat fixed under warrenty before you swap out the oe clutch!
Old May 24, 2006 | 07:55 AM
EvoTio's Avatar
Do you have a Centerforce clutch installed on your car?
Old May 24, 2006 | 08:05 AM
ruchc03's Avatar
ACT-HDSS is the clutch kit I have, got the clutch/flywheel combo for only $759.99 (not including shipping) from ProStreet here: Lancer Evolution 8 ACT Clutches - In stock, and ready to ship! 10% OFF
I ended up getting the ACT Flywheel instead of the Proweight for 50.00 bucks more... but that's the price I paid all said and done.
A little stiffer clutch engagement... but nothing stressful to the leg/ankle what so ever! I like it a lot actually! And it shifts just like stock, as in=disengages and engages the same... I also took the restrictor valve out of the release cylinder, so engagement is more direct than before.
Old May 24, 2006 | 08:08 AM
EvoTio's Avatar
Are you having any high RPM lock out issues when you shift? I've been hearing alot of this with the ACT clutches.
Old May 24, 2006 | 08:12 AM
sleet's Avatar
That issue was solved already, it just has to be adjusted.
Old May 24, 2006 | 10:19 AM
anjapower's Avatar
stick with the stock clutch. if you're not dragracing and want the stock feel and engagement, there's nothing better for that power level.
Old May 24, 2006 | 10:45 AM
Warrtalon's Avatar
Definitely stick with stock. I don't know who these guys are saying the ACT feels like stock - it feels NOTHING like stock. IT's way, way, way stiffer than the stock clutch. That doesn't bother me in the least, but if someone asked for a replacement clutch that was just like stock, the last thing I'd recommend is the ACT HDSS. For all of you who suggested ACT, go find an Evo with a stock clutch and try to drive it. I went and test drove a IX, and the clutch pedal was so soft, I thought it was broken. It doesn't even feel like it's there - that's how drastic the difference is.
Btw, sleet, the adjustment is only a temporary fix. It comes back over time, and is a royal pain in the ***.
Old May 24, 2006 | 10:52 AM
meanmud's Avatar
I had 2 clutches:
HKS GD Max -
ATS carbon/carbon ($$$$) - Very stock like feel; however, the chatter was very twin-disk
Stick with Stock if you can
Old May 24, 2006 | 11:08 AM
Anarchy99's Avatar
It's not as bad as all that. The feel of the HDSS is not much different, I felt my OEM clutch and then sat in a car with the HDSS with out the pill in ether car and the pedal feel was not that much different at all. Now if we had said the XTSS now that’s not for the week.
Old May 24, 2006 | 11:16 AM
Warrtalon's Avatar
No way, Anarchy. IT is a DRASTIC DIFFERENCE. There's no way you did what you just said and felt little difference. Like I said, I went to a stock IX and thought the clutch pedal was broken, because it offered no resistance. We're talking 2200# vs 2900# - huge difference. The XTSS is only 200# more than the HDSS.
