Buschur Racing's 9.7 @ 150 mph pass....The Video.
Old May 24, 2006 | 10:45 AM
David Buschur's Avatar
Here you go guys. We did not get the 9.60 on video. Wait until you see how much is left in the car from this pass. Note the black smoke pouring out of the car the entire pass, AFR's on this run are in the 10:1 range. Also note the bog after the launch.
We were out with the car last night made 7 more passes, couple of high 9's but the shuts off when it goes to 4th gear. We are doing some re-wiring today to try and find the problem. My prediction is.........
Buschur's 9.7 pass
Old May 24, 2006 | 10:50 AM
KOEvo's Avatar
Ha, nuts. Glad i could be the first to view that for you .
Old May 24, 2006 | 10:55 AM
mac_05evo's Avatar
looks like a good run, especially with the bog and the rich AFR's
Old May 24, 2006 | 10:58 AM
VTECH8TR's Avatar
Dave,
That is SWEET man. Congrats and Good luck brother .
Old May 24, 2006 | 11:00 AM
sscollision's Avatar
that thing is bad ***!!!when i get my car fix it's coming to you!!!
kmcconn9's Avatar
/\ my thoughts exactly....new record....I think so..
Old May 24, 2006 | 11:08 AM
PhoenixEvo's Avatar
Congrats!!!!!
559EVO's Avatar
That was bad ***,I take it it was a clutch drop right?
Old May 24, 2006 | 11:14 AM
DCSilvrEvo's Avatar
Good shyt
Old May 24, 2006 | 11:17 AM
nigletsyz's Avatar
Why did you run the car so rich?
Old May 24, 2006 | 11:28 AM
mchuang's Avatar
Very nice. Make me proud to own an EVO. Just out of curiousity what is the full weight of the car with driver if you know?
Old May 24, 2006 | 11:33 AM
BigBADGSX's Avatar
good stuff dave... My bro was @ 42 last night, he said you guys made a couple of decent runs but then it just seemed like you where having some problems.
good luck next time out.
Old May 24, 2006 | 11:54 AM
The car is rich because we aren't ready to release the full fury yet There is something up with the ECU loosing power right now and we are trying to find it. That's what was with D42 last night, top 3rd gear-low end of 4th the car was shutting off like the key was just turned off.
Weight with my brother in the car and less than 1/2 tank of fuel was 3033 pounds. It is no lightweight.
The car still has the complete full factory interior in it. Seats, door panels, center counsole, full dash, glove box door, carpet etc. Radio is in the car with two speakers, power windows work in the front and the power sunroof is in and works. All of the factory glass in in the car. We've obviously removed some weight what little we have taken out has been offset by the rollcage that is in it.
Going back tonight, we should have the wiring fixed. Car is getting a ton of passes on it for no good reason, just trying to find the problem.
That is not a clutch drop launch either. It was an attempt to slip it and just ended up a little to heavy on the clutch.
Old May 24, 2006 | 12:13 PM
byron3636's Avatar
I call BS on the 9.6 ... jk... good going... not bad for like $15k in parts... I like that the car is black.
Old May 24, 2006 | 01:05 PM
deadbeatrec's Avatar
dammmn
