zero-lift-kit & Rhino ramps?
Old May 30, 2006 | 11:46 AM
zmeli's Avatar
To Those of you that have a Zero-lift-kit, can you still drive up Rhino Ramps?
Thanks.
Old May 30, 2006 | 01:35 PM
Uncle Boo's Avatar
Rhino ramps work with the zero lift kit. The flexible rubber lip hits just slightly. I have installed the Beatrush Underpanel and that works too.
On my C5 I just use 2 blocks of 2x12's just before the ramps and the lip clears, and that lip is much lower. You can always go that route if you ever lower the car.
Old May 30, 2006 | 01:37 PM
zmeli's Avatar
Thanks for the reply, I was thinking about adding the kit some day.
Old May 30, 2006 | 01:49 PM
DocMortal's Avatar
It clears rubs a very little..
Old May 30, 2006 | 03:29 PM
sonicnofadz's Avatar
I just jack up the car (using a wooden 2x4 block as a pad) and slide the ramp underneath. Takes almost as much time as setting up the ramps =)
crankIT
Jun 10, 2011 10:14 AM
DarwinX
Feb 21, 2011 10:45 AM
OsoiCT9A
Nov 17, 2010 10:25 AM
silex
Mar 16, 2007 06:32 PM
boostedwrx
Oct 15, 2006 06:55 PM
