Idling Weird.
Old Jun 10, 2006 | 03:16 PM
MonsterEVOO's Avatar
Idling Weird.
Well When im in Nutrual.. My rpms are around 700-1000.. But I Just noticed that it Jumps around from 700-1000... And i have a Blown Turbo.. Any ideas?
Old Jun 10, 2006 | 03:18 PM
smokedmustang's Avatar
Any ideas? how 'bout: WHAT DID YOU SAY?? I don't get what you are saying. Re word it!!
Old Jun 10, 2006 | 03:22 PM
occultworks's Avatar
Okay, I think your idle is the least of your worries if you have a blown turbo.
Also, you need to include more info. You told us nothing. "Your idle is whack because you need to align your flux capacitor. The light grease is at least 10 degrees off causing an uneven load on the electrical system. Take it to the dealer to get it fixed under warranty."
Old Jun 10, 2006 | 03:25 PM
Well i drove it and i came into a light.. And i was staying still and my car would shake and the Rpms Would go up and down as if im reving it (i wasnt it) the Rpms Jumping Rangend from 700-1000Rpms I was thinking is this happening Because of my Blown Turbo or do i have a hole new problem with my car.
Old Jun 10, 2006 | 03:32 PM
Be careful over there, and thanks for serving our Country Bro!! I better check my light grease!!
Old Jun 10, 2006 | 03:33 PM
How do you know the turbo is blown?? Do you know how to check it??
Old Jun 10, 2006 | 03:35 PM
Carmax Checked it for me.
LoL, thanks!
MonsterEVOO, I would try to get that blown turbo situation fixed first. In the mean-time, what do you have done to your car? Did you change anything before it started this weird idle situation?
Man, driving around with a blown turbo can't be good.
Old Jun 10, 2006 | 03:37 PM
Well all i installed was a Injen Intake System and i just had goten my car back from the Dealer cuz i had to get a new T C.. i dont beat on my evo I use to but not anymore.... What problems can Driveing around in a blown turbo lead to?
Old Jun 10, 2006 | 03:38 PM
Thats like going to Walmart, and having the greeter check your prostate.
Take the hoses off the turbo, use your index finger and thumb, and wiggle the "shaft" in there, up and down, there should be MINIMAL play in there, also look for leaking fluid all over the place, which will be from blow-by of oil I will post photo up in a minute!
Old Jun 10, 2006 | 03:41 PM
I DOUBT YOU HAVE A BLOWN TURBO!! Does it make noise? Please give us the Scenario, what the car does, mods, miles, sounds, smells, etc... I cant play this "go fish" for answers stuff!!! Sit down and explain this better!! I dont want to go 45 pages deep, only to find out, you accidentally put Diesel in your gastank!!
Old Jun 10, 2006 | 03:44 PM
Umm, yeah. The uneven idle is probably caused by your new Injen intake. You know, for some reason I already knew you had an intake. Go figure.
Old Jun 10, 2006 | 03:46 PM
Lol 1st no i didnt Put Diesel... Well When i Give it Gas there is no power whats soo Ever and When ever I build Boost My car sounds like it has a Supercharger(alot like a Saw turned on) isnted of a Turbo... it Smells Very Rich.. i dont have a boost Gauge But I gave it Gas once and Nothing happens Just a Wine. Hope this helped.
Old Jun 10, 2006 | 03:56 PM
mac_05evo's Avatar
the idle is from your aftermarket intake.. it causes the readings of the mass air flow sensor to be changed and the car is searching for stoich.. one second it will be lean then the next rich trying to compensate to get that stoich setting that's why it is idling up and down.. if you put the stock intake back on it should go away..
marcouxa1
51
Jan 10, 2016 06:47 PM
Asmodeus6
26
Oct 8, 2009 05:49 AM
xspsi4
50
Jun 28, 2009 10:52 AM
Drive02Lancer
13
Mar 22, 2004 03:09 PM
