^techna Fit Clutch Line
Old Jun 20, 2006 | 09:00 AM
Drift4's Avatar
Does Techna Fit have angled banjo fitting by the clutch master cynlider like the O.E. hose. Or who make a better line than Techna Fit? Thanks
Old Jun 21, 2006 | 10:30 AM
gklasse's Avatar
The banjo fitting on the standard Techna Fit clutch line does have a slight angle, but not the same curve at the end like the original fitting. However, it should work fine (might just be a little harder to get on without dropping something). Also, Techna Fit does offer custom lines so you may be able to order one exactly the way you want it.
I ended up using a Speed Source clutch line which does have the curve at the end of the fitting. I think Works also offers one with the curve.
Hope that helps.
geo
Old Jun 21, 2006 | 07:19 PM
Drift4's Avatar
Yeah there is a slight bend, but not like the original rubber hose line. I might put it on a vise and very gently add more of an angle...should be good. My hands are kinda small and could move around the area behind the shock tower.
I plan to remove the restrictor on the slave since i am doing this.
I just hope the pedal feel will be better in terms of clutch engagement.
