HID foglights...
Old Apr 30, 2003 | 09:50 AM
jotan82's Avatar
HID foglights...
i want to run HID's in my fog lights, cuz i hate the holgen contrast when i have the normal lights on...
do you know the bulb size of our fog lights?
also, what is the light output of the normal headlights so I can get the same light output...
tnx for your help
Old Apr 30, 2003 | 09:53 AM
Jonasan50's Avatar
Your best bet would probably to get regular ultra-white halogens, for a replacement. rather than spend 400 bucks on another H.I.D. set...
Old Apr 30, 2003 | 10:16 AM
netmand's Avatar
If I recall correctly off the top of my head the manual says the fog lights are H11 bulbs. No luck yet on casual looking around.
Old Apr 30, 2003 | 11:44 AM
cecilia's Avatar
why does our lights up front have this outline of the light when you turn it on can you ajust that, because it gets on my nerves, and you know even when you manually ajust it with that switch, it still doesn't go away....I need some suggestions
Old Apr 30, 2003 | 12:39 PM
JasonS's Avatar
If it's like the Audi's HID setup, there is a template which is cut to provide the sharp cut-off for the HID's so they don't blind oncoming drivers. IIRC, it's between the actual bulb and the lens on the Audi.
I think you'd have to take apart the light assembly to remove the template, if that's even possible on our Evo.
Hope that helps...
Old Apr 30, 2003 | 01:12 PM
netmand's Avatar
http://faq.auto.light.tripod.com/aux-ligths.htm
Has some good info and things to think about.
http://www.lightingresearch.com/metal_white.htm
Found this place that seems to have bulbs that would match the fog light color temp closer to the HID's.
Let us know what you do. I'm interested in your outcome.
edit: BTW, Most photographers prefer a wider color temp range (sunlight being the best) to bring out all details in what they shoot. Keep that in mind... So it may look a bit off but orange to blue color temps may actually help you see better at night.... Just a thought.
Old Apr 30, 2003 | 02:12 PM
lil'evil_evo's Avatar
Are we sure they are H-11 I am looking for the booklet to check, but can't find the it. I want some bad. Thaks for the find netmand
Old Apr 30, 2003 | 03:01 PM
Coolguy949's Avatar
HIDs in your fog light housing will blind everyone on the road. Thats why HID "kits" for halogen housings are no good. The housing needs to be DOT approved for HID.......meaning the housing allows the light output to emit in a certain way that it doesnt blind people. THe projectors have the plate so you dont blind everyone on the road. My advice, dont touch the protective plate.
If you want an accurate HID output for your fog lamps you should buy evo 7 headlights because they have projectors for fog lamps instead of reflector type. Then get an H11 rebased bulb kit with d2s bulbs (d2r is for reflective housings like lexus, acura). Even halogen projectors have the little plate to correct the beam pattern. An HID fog lamp conversion for evo 7 housings would probably work perfectly and give you a perfect beam pattern. Prepare to spend about 800 - 1000 bucks though.
Rob
Old Apr 30, 2003 | 03:19 PM
EvoJimbo's Avatar
Does anyone know if I can replace the factory HID bulbs with a higher tempature one like 5000k - 8000k. I want that bluish tone to teh light. If so, where can I get them and waht harness size will i be lookin for?
Old Apr 30, 2003 | 03:34 PM
Coolguy949's Avatar
yeah, you can........ you want to replace them with D2S HID bulbs. I recommend some philips ultinon or osram xenarc 6000K ones.
Old Apr 30, 2003 | 03:40 PM
EvoJimbo's Avatar
Thanx COolguy
Old Apr 30, 2003 | 04:01 PM
Obsoleteasian's Avatar
Ya i was thinking of replacing the FOG lights with some super whites or blues.. has anyone found the size of them,, h2?..
Old Apr 30, 2003 | 04:15 PM
Evo11V's Avatar
Veteran: Army
Dont forget the Fog lamp housing is also used for air flow to cool the tires/breaks.
Old Apr 30, 2003 | 08:24 PM
netmand's Avatar
Light Bulb Chart in the owner's manual:
http://www.collectracecars.com/evo/i...ight_chart.jpg
Note the High beam is not HID either, muahahaha...
man you gonna spend some serious cash...
Old Apr 30, 2003 | 08:31 PM
EvOLcHiN's Avatar
I have already changed the fogs. They are h11's. Kinda hard to find bulbs because none of the big names make h11 superwhites yet.
