Any site with detailed explanations of Defi BF and Control unit installs?
The best I can find is a write up for a D-series boost gauge on EvoM, but I'm having a lot of trouble finding really good write-ups other than that. I need to install an Oil Pres. EGT, Boost and CU.
Anyone with any advice?
Also, do the stock MR gauges have to be removed or disconnected in order to install aftermarket ones?
Thanks,
-Aaron
Thanks,
-Aaron
To get you started.. http://evomoto.com/index_tech.php?tP...20469807920d8f
and https://www.evolutionm.net/forums/sh...t=defi+install
as well as https://www.evolutionm.net/forums/sh...t=defi+install
There should also be instructions with the gauges themselves.
Hope this helps.
Hope this helps.
