a/f can someone confirm this
is this the correct ecu pin layout for the evo9 ecu?
https://www.evolutionm.net/forums/at...chmentid=81061
and do i just splice it in with 71 the white wire??
too many threads and they dont state between evo 8 or 9.
thanks in advance for the help. and if this is not the correct way for a/f evo 9 can you post me in the right direction.
YES I KNOW ITS NARROWBAND but it will do for now.
yep The Diagram Seems to be Correct, Connector c-115 pin 71 and wire color wh. That would be the Left most Connector. There May be multiple white wires soo make sure you have the right pin. Where did you get taht pin out form?
i found it on the fourm. now im confused. if i have my head under the dash and looking up its on the left side on passenger side. ? can i splice into it there or should i go out to where the o2 sensor is under the engine cover thing.
