Fuel pump kit?
Old Sep 30, 2006 | 12:04 AM
evoryne's Avatar
Fuel pump kit?
Hey guys so im getting a Walbro 255 fuel pump and i was wondering if i should get the kit or not, can someone tell me what comes in the kit and if its worth the extra 20 bucks. and is it safe to install it without a reflash or fuel managment?
Thanks
Old Sep 30, 2006 | 12:22 AM
Evo8zip's Avatar
i have mine sitting here waiting to install it....not sure in the dif with what comes with the kit but its safe to install it without a flash/em/fm
Old Sep 30, 2006 | 04:58 AM
sparky's Avatar
Get the kit as it comes with a rubber spacer. The Walbro pump is about 1/8" shorter than the stock pump. The spacer keeps the pump properly seated and assures that all fuel pumped is delivered into the fuel line. You'll get a new filter sock as well.
I installed my pump w/o the spacer and had fuel delivery problems. So, I had to fabricate the spacer.
Old Sep 30, 2006 | 12:16 PM
evo150's Avatar
trust me, get the kit. it will come with the new plastic spacer as stated by sparky aswell as a new fuel filter. i have a 03 evo8 with only 40,000 miles and it was dirty, and i only run 93 oct sunoco gas. after you get the kit, www.evomoto.com has a perfect install guide
Old Sep 30, 2006 | 12:52 PM
blackevoguy's Avatar
buy the kit its worth it like they said. Evomoto has a great right up and its really easy to do. I have one in mine without a flash and everything is a ok.
Old Sep 30, 2006 | 02:20 PM
SpoonEvo's Avatar
I have the pump...where can I get the kit only?
Old Sep 30, 2006 | 02:28 PM
elhalisf's Avatar
no kit needed. i have installed a number of fuel pumps in evo's other than mine. never bought the kit and never had problems with installing it without the kit. i know for a fact that you dont need a spacer for the fuel pump to operate "properly"
