Disabling the Clutch Safety Switch?
Is there a write up on how to disable the clutch safety switch. Or a picture or something, i know with DSM's you just remove the green wire. What do you do on an evo to disable it?
what year is your evo?
https://www.evolutionm.net/forums/sh...ve+rev+limiter
You don't need a write-up. It's the white connector right near the bottom of the clutch. A monkey could do it blind-folded with a banana in one hand. I disconnected mine right away.
The clutch safety switch makes it so you have to push in the clutch to start the car. Disabling the switch allows you to turn on the car without pushing in the clutch as you would normally do. Just make sure your car is not in gear when you start it obviously.
so the white connector is only associated with the clutch safety switch?
Also i have an 05 and i have no launch limiter. and that connector is plugged in? Is it possible to change the launch limiter with ECU Flash?
ya my bad i found the answer to all those questions already, but thanks anyways. The only weird thing i noticed that bottom 1 set for the clutch safety switch, the actual plastic rod or whatever you want to call it dosent get pushed in by the clutch pedal? why is it there then?
