What is the lighest LICP???? and Lighest FMIC??
Old Nov 1, 2006 | 11:53 AM
v8k1ller's Avatar
Anyone know the lighest LICP? My bet is on NISEI..
how about lighest FMIC??
trying to lose weight upfront on the front heavy evo
Old Nov 1, 2006 | 11:55 AM
dustin03's Avatar
nisei would be the lighest..... On a fmic lighter is not better
Old Nov 1, 2006 | 12:20 PM
KevinD's Avatar
the stock LIP is pretty dang light. the stock IC is way lighter then aftermarket ones too..
Old Nov 1, 2006 | 12:25 PM
58177's Avatar
I agree the stock IC and pipes are probably the lightest set up you'll be able to find up to 400hp.
Old Nov 1, 2006 | 12:29 PM
pog0's Avatar
Nisei usually sells their LICP as steel and not aluminum. My AMS lower pipe was light as hell, maybe 1-1.5 lbs? Anything aluminum will be light.
As for FMIC, no clue on that.
Old Nov 1, 2006 | 12:32 PM
dustin03's Avatar
this info is wrong the lower ic pipe by Nisei is aluminum I have one
Old Nov 1, 2006 | 12:35 PM
BMWE30's Avatar
Nisei offer both setups obviously the aluminum one if going to cost you a few dollars over the heavier steel one.
Justin
Old Nov 1, 2006 | 12:36 PM
fugiwara's Avatar
you are wrong too, NISEI sell both steel and aluminum...
Old Nov 1, 2006 | 12:38 PM
fugiwara's Avatar
I just received my fighters garage licp, it is very light... I pick up the box from my mailman and i can't believe how light the box was when I picked it up
Old Nov 1, 2006 | 12:40 PM
tvbf1's Avatar
I read somewhere that the ARC intercooler is the weight as the stock one, so if the if the stock fmic is the lightest then the ARC is in the same category then.
Old Nov 1, 2006 | 12:59 PM
EVOSlayer's Avatar
Yea Nisei sells aluminum and a 1018 steel version.
Have you considered a mini battery as well?
As far as FMIC, if you want light, go with a tube fin design. Bar and plate designs cool more efficiently but are heavier.
Old Nov 2, 2006 | 11:02 AM
kekek's Avatar
The OEM LICP is about 2.5 lbs. The Buschur replacement (steel) is approx 3.5 lbs.
Old Nov 2, 2006 | 11:17 AM
pog0's Avatar
Well I meant that it was more common to see steel pipes from Nisei because of the price. Yeah, they sell both, but usually they are steel over aluminum.
Old Nov 2, 2006 | 11:22 AM
kmcconn9's Avatar
The bar and plate design of most aftermarket fmic are going to perform better than the tube and fin design but the bar and plate will be heavier.....
Honestly the weight of the fmic shoudl be your last concern and the performance should come first...
I would go with Buschur...
Old Nov 2, 2006 | 11:25 AM
MitsuJoe's Avatar
The LPI licp that I have came in a box with couplers and was less than 3 lbsaccording to UPS.
