gas gauge problem
Old Nov 3, 2006 | 03:38 PM
03silevo's Avatar
gas gauge problem
I swapped out my fuel pump this past weekend thought the walbro went bad but it didnt thats besides the point......i replaced the pump with a new one and put everything exactly back the way that is came out.....being very careful and everything during the whole wiggling process those of you that installed yours know what i mean....well anyways and i put the pump back in the tank everything hooked up right float moves freely everything but now my damn gas gauge doesnt work ...... ARGGGGGGGG.... all the help it appreicated thanks
Old Nov 3, 2006 | 03:45 PM
ak47po's Avatar
Did you diconnected the negative battery cable when you changed the pump?Could be a blown fuse.
Old Nov 3, 2006 | 05:44 PM
kapolani's Avatar
You probably damaged it.
My shop said that you have to be careful when installing because the sensor is very easy to damage.
Old Nov 4, 2006 | 09:05 AM
03silevo's Avatar
what fuse could i have blown cuz that might be it the sensor though i was very very very careful working it out
Old Nov 4, 2006 | 11:20 AM
IX stealth MR's Avatar
You probably broke the floater. Its very easy to do with all the wiggling to get it in. I bent mine a little bit also.
