Coin holder removal
Old Dec 29, 2006 | 03:34 PM
EvoEvol's Avatar
Coin holder removal
On a IX MR, I took the 2 screws out from the storage bin, and it lifts up half way, but it seems to be stuck towards the shifter end. Does anyone know if there are tabs on the front? I don't wanna snap somthing off.
Old Dec 29, 2006 | 03:51 PM
TVA's Avatar
TVA
The pocket in the second DIN spot? Remove the two screws on the roof and pull towards the rear of the car, there are two tabs on the lower half.
Old Dec 29, 2006 | 03:53 PM
EvoEvol's Avatar
doh! I mean DRINK HOLDER, the whole console piece.
Old Dec 29, 2006 | 03:56 PM
TVA's Avatar
TVA
Ah, remove the two screws in the floor of the center console pocket and lift up just in front of the drink holder, there are two tabs holding the first half of the center console to the floor about an inch behind the bottom curve of the shifter surround.
Old Dec 29, 2006 | 04:00 PM
EvoEvol's Avatar
So pull straight up and the tabs will pop loose? I pulled real hard and it felt very tight towards the shifter console.
Old Dec 29, 2006 | 04:13 PM
TVA's Avatar
TVA
Check out pictue number 11 http://evomoto.com/tech_info.php?tPa...42de07660f4e8d and you'll see the holes in which the tabs go into. Just above the yellow circles.
Old Dec 29, 2006 | 04:17 PM
EvoEvol's Avatar
thanks!
h.funk's Avatar
You have to pull harder than you want to.
Old Dec 29, 2006 | 04:18 PM
TVA's Avatar
TVA
Originally Posted by EvoEvol
thanks!
NP, you get it off? What are you doing with the center console off?
Old Dec 29, 2006 | 04:27 PM
EvoEvol's Avatar
Installing a Blitz Turbo Timer, I just put it all back because it's getting dark.. but that pic of the tab location helps a ton.
Old Dec 29, 2006 | 04:31 PM
TVA's Avatar
TVA
Very nice. Thats a great how-to for the installation of a TT.
reliablefr
18
Aug 30, 2012 11:46 PM
06RS
Jul 11, 2007 06:57 PM
