evo 9 turbo on evo 8?? need info
Old Jan 7, 2007 | 01:02 AM
Turd Squirter's Avatar
Originally Posted by ak47po
Stage 2 Mitsubishi Evo 9 TME titainium-aluminide turbo & 20G upgrade new, with 10.5 Large Single Puck Turbine Housing. Rated for 450HP, plus it spools quicker!
http://www.lancershop.com/customer/p...&cat=17&page=1
Read closely though...
TECH TIP: This is a direct bolt on turbo. This is an upgraded Mitsubishi 49378-01580 turbo
This is a just a tweaked OEM 16G.
Old Jan 7, 2007 | 06:04 AM
evilevo2006's Avatar
so it is not a true evo 9 turbo then tweaked or what am i missing here. how would this compare to the stock 9 turbo then??? maby im getting in to deep now and should just leave it where im at and do the reg evo 9 turbo. lol
Old Jan 7, 2007 | 06:16 AM
prj.evo's Avatar
Originally Posted by evilevo2006
but how does the evo 9 turbo hold boost uptop compared to the 05evo8 turbo.
how is the 9 turbo on the evo8 uptop in that matter.
i would like to know how the 9 turbo taper's on the evo 8.
lol
I have heard that the 9 turbo tapers just the same if not more, but it makes more midrange power and torque. However, none of this is justified, only what I have read and heard from IX owners.
Old Jan 7, 2007 | 07:15 AM
bigric09's Avatar
Yeah I think you pretty much nailed it. The 16G IX is not a big numbers turbo, nor is any 16G on an Evo really. I think it's a great street turbo though with awesome autoX and road course potential. It's not a bad drag racing snail but it's definately not optimal for that application either if you're trying to crack into the 11's or 10's. It is however a 100% bolt-on affair with 100% OEM parts. Plug and play really. Until somebody creates an affordable 50 trim kit that retains an OEM-ish look, I think this is our best option on pump. Good luck with every thing dude.
i think you should look at my sig lol.... the time is before ported mani, ported hotside, and o2 housing, no custom tune, no cams, no ebc, terrible tires....
Old Jan 7, 2007 | 07:17 AM
bigric09's Avatar
Originally Posted by prj.evo
lol
that is exactly how it feels, the taper can be controlled a little, but as i posted early, the taper is a design thing.. but it definitely has more torque and power in the midrange then all of the viii's i've been in and all of the viii's i've done some spirited driving with. just some minor tuning and it doesnt fall off like the viii's do.
Old Jan 7, 2007 | 10:24 AM
thatsMR2u's Avatar
With what kind of fuel? I haven't seen the 20G IX doing anything significant over the 16G IX until it's given some 100 octane.
Pump Gas and Meth Injection tuned by myself- and i know the IX does not come with 20g wheel - im just saying the IX compressor housing is able to hold good boost in its stock form
Old Jan 7, 2007 | 11:34 AM
It began life as a 100% OEM Mitsubishi 16G and from the outside it still looks like the same turbo. However the OEM 16G compressor wheel has been replaced with a larger, 20G wheel. It would take a week to explain the difference in performance between the two. I'll let the Buschurite disciples do that. Just understand that Mitsubishi does not and has not ever manufactured a 20G for the Evo.
Old Jan 7, 2007 | 11:50 AM
o.e.boost's Avatar
i've always wanted to throw my 03 with the ix turbo on the dyno but never came up to doing it...i have basic mods...full tbe, mbc, intake/dropin...but have yet to tune the car...im planning on calling andy/speedelement but have yet to find a possible day!!!...how the car feel with the ix turbo after the tune turdsquirter?
Old Jan 7, 2007 | 11:55 AM
It hauls man. Call Andy and see what your schedules look like. The improvement will be like night and day. Right now he's doing his tunes at EIP in San Jose but Speed Element just picked up a gorgeous new dyno! When I was there on Friday it was still boxed up. Can't wait to see everything all setup over there.
Free Speed Element plug above. Andy now you gotta give me a good deal on that IX front end swap.
Old Jan 7, 2007 | 12:16 PM
o.e.boost's Avatar
im still waiting for their dyno to get installed as a matter of fact...but wait are you running walbro 255 or a stocker?...i assume a 255 right...i have a ix pump and andy has already confirmed that the ix pump should be good enough and i might as well use it since i bought it!!!...damn i should of just bought a 255lb...
Old Jan 7, 2007 | 12:20 PM
If Andy told you it's fine that's good enough for me. I have a Walbro 255lpm but the IX stocker is strong too.
Old Jan 7, 2007 | 12:32 PM
o.e.boost's Avatar
all i can say from my experience is that bolting up the ix 16g to my 03 9.8 16g was a pretty big improvement...it pulls a whole lot harder throughout the power band...the power delivery uptop does die but midrange power has increased...aleast thats what my but dyno says...i even did a placebo(friend)...who didnt know the swap was going to occur...so i had him drive before and after!!!
Old Jan 7, 2007 | 01:54 PM
EvoDan2004's Avatar
so did it taper like the 8 turbo did or hold boost a little bit better?? and does it pull uptop better or the same then the 8 turbo??
Old Jan 7, 2007 | 08:51 PM
so anyone else with any data to this thread??
Old Jan 8, 2007 | 01:53 AM
o.e.boost's Avatar
right now my mbc is set at 18lbs all the way to redline but when i did the swap the stock ebc system was still intack...
