how can i roll intake piping ends???
Old Feb 5, 2007 | 12:38 PM
ApexVIII's Avatar
how can i roll the end of intercooler piping so it wont pop off? and ideas?
Old Feb 5, 2007 | 12:40 PM
KartaRailed's Avatar
A blow torch and a small hammer and a vice clamp. Just tap it out so it looks like a horn, its gonna look ghetto, but once the tbolt clamp is around it and the silicone coupler is covering it whos gonna notice.
Old Feb 5, 2007 | 12:47 PM
PPI's Avatar
PPI
If there is a bead on the pipe all you should need is a good clamp, preferrably a t-bolt.
Old Feb 5, 2007 | 12:48 PM
bvdawg13's Avatar
have you tried a t-bolt clamp?
Old Feb 5, 2007 | 01:25 PM
djtmotorsports's Avatar
This is the tool I use at my shop http://vansantent.com/bead_tool.htm
Darin
Old Feb 5, 2007 | 02:19 PM
Speed Corps's Avatar
Former Vendor
You could also run a bead of weld around the end of the pipe.
Old Feb 5, 2007 | 02:24 PM
Spaceball 1's Avatar
I welded a peice of drill rod to a pair of old vise grips and grinded out a notch for the drill rod to fit into. I have only used it on aluminum and does a way better job than you would expect. It takes about ten minutes per tube.
Old Feb 5, 2007 | 03:29 PM
ApexVIII's Avatar
thanks guys. see there is nothing on the end no bead or anything i dont have a welder so i can weld anything on it. i will try hammering it out a little it should hold
Old Feb 5, 2007 | 03:38 PM
zlancer's Avatar
i run 28psi in my minivan and none of my pipes are bead rolled. but i do have t-bolt clamps. havn't popped a pipe off yet.
Old Feb 5, 2007 | 05:02 PM
steelrain202's Avatar
t bolts are the way to go. hell they were designed for fittings on fighter aitcraft talk about boost lol!
