5th grear grind warrantee info plz!!!!
Old Mar 13, 2007 | 04:54 PM
Noize's Avatar
EvoM Administrator
If you just got the grind, I've seen a couple cars with 4th gear grinds be totally cured by BG Synchroshift. My VIII started this at 22k, I changed to BG, and it was butter at 53k still when I sold it. BG is really nice stuff.
Never had a 5th gear grind, but its worth trying.
Old Mar 13, 2007 | 05:24 PM
steevo's Avatar
Had my 5th replaced with cams. It's a toss-up.
Old Mar 13, 2007 | 06:24 PM
thaigleshmk's Avatar
Um. I use the same fluid, but it doesn't cure it on my transmission at all. It makes it smoother but I still have the grind from 4th to 5th (after 5k rpm).... ... Man..
Old Mar 13, 2007 | 06:47 PM
nos51's Avatar
i got used to my grind i guess...
