deelectric grease
Old Mar 18, 2007 | 03:03 PM
whitersevo's Avatar
deelectric grease
hey I am replacing the boots on the coil packs, and it says to put some deelectric grease (provided) to the inside of the spark plug side boot??? it just loosing me there!! any one know what it means thnxs.
Old Mar 18, 2007 | 03:05 PM
Curt@MrLed's Avatar
Former Vendor
you dont know how to dilectric grease in there..
Old Mar 18, 2007 | 03:08 PM
whitersevo's Avatar
just dont understand where it suppose to go bro... not that I dont know how to do it... does it go where the boot meets the coil pack or where the spark plug meets the boot..
Old Mar 18, 2007 | 03:10 PM
Curt@MrLed's Avatar
Former Vendor
it goes where the metal to metal contact goes... its stops corrosion..
Old Mar 18, 2007 | 03:13 PM
D_Eclipse9916's Avatar
Use it if you like nice connections, but it does get messy.
Old Mar 18, 2007 | 05:17 PM
barneyb's Avatar
Use it on any rubber parts you'd like to get apart later. The sparkplug boot, for example, likes to bond to the plug porcelain given some time and heat.
Also, as above, use it on the metal parts that snap together to make them easier to remove later.
Old Mar 18, 2007 | 06:08 PM
2theMAX's Avatar
Just put a little bit in the coil pack. Use a q-tip right inside the igniter portion where it goes over the spark plug.
