What to do with Boost gauge hose?
Old Apr 16, 2007 | 02:29 AM
AhmadHasib's Avatar
I'm planning on purchasing the Orbital kit for my car to install a Double din screen into the car. I have the MR gauges in the car. Since the Orbital moves the A/C controls to where the boost gauge currently is, I'm going to temp. take the boost gauge off, until i decide to buy a better one and relocate it somewhere else.
Question: Will I have to plug up the hose that attaches to the boost/vac gauge with something if i take the Boost gauge off? If so, what can I use to plug it up with? Thanks for your time
Old Apr 16, 2007 | 09:07 AM
Rod Munch's Avatar
It's a trivial amount of air flowing through that tiny hose, but you could easily crimp it off temporarily with a plastic zip tie / cable tie; just bend the end over and tie it off.
Old Apr 16, 2007 | 09:48 AM
hondafan's Avatar
or put a screw in it.
Old Apr 16, 2007 | 10:09 AM
EvoSid's Avatar
a golf tee works too.
Old Apr 16, 2007 | 10:54 AM
Rod Munch's Avatar
Those are both good ideas (screw or golf tee) with normal vacuum hoses, but this one is a little different: I just installed the MR gauges, and the rubber hose connects to the gauge nipple with a thin brass tube that spans the two rubber ends: When you disconnect the hose, the tube remains sticking out of it. So the crimping approach may be best in this particular case.
Old Apr 16, 2007 | 09:32 PM
AhmadHasib's Avatar
thanks for all the help
Old Apr 16, 2007 | 09:49 PM
chaotichoax's Avatar
I did the gold tee method
worked like a charm
Old Apr 17, 2007 | 12:19 AM
chrismnj's Avatar
now u gonna wait like 2months for that kit
Old Apr 17, 2007 | 12:20 AM
newimportowner's Avatar
plug it.
