Stock mr oil temperature guage not working
So after I decided to change the stock guages around so I can have the boost guage from the right to the left, the oil temperature guage decides not to work. What might be the problem? it still lights up and stuff, just the needle don't move any more even if the car is warm.
All of the positive and negative wires for all three of the gauges illumination and the voltage gauge run to two common wires. The only other wire is from the oil sender to the oil temp gauge. If the illumination wires for the temp gauge were backwards, the light bulb would still work just fine. The gauge however would not. Check the polarity of the common wires used to light the gauges.
