Tricks to make TBE quiet?
I am going to Germany soon and need to know if there are any tricks to make my car quieter for the inspection when I pick my car up. I have a Buschur TBE/HFC/Magnaflow combo. I have to be under 95db, any ideas?
Is it only for the inspection or for the entire time you are driving around?
If it is just for the isnpection, I would say since there is only four bolts on the Cat, just bring a stock cat with you and throw it on for the inspection, then switch back.
Put in a resonator right before the muffler. Does amazing things for the sound quality, but it will probably rob you of 3-5 HP because of the turbulence it creates in the exhaust stream....
I have heard of stuffing the exhaust with steelwhool? does it work? I dont plan on unbolting at all. I will pay them out if I have too!
Do you have any sound clips of your setup? How loud does it sound to you compared to stock? This is the exact setup I've been considering, but I don't want it to be too loud. Deep and throaty sounding is okay, but not buzzy or LOUD.
The buschur magnaflow catback with a stock cat is very quiet.......even when i put the test pipe on it still isnt "that" loud until you go wot, but even then it isnt as loud as some others I have heard.
http://buschurforums.com/forum/showthread.php?t=15732
read post #4, should give you an answer
