Helix HFC and still check engine
Old Jul 23, 2007 | 05:02 AM
joey0480's Avatar
Ugh, just wanted to vent. Had the TBE put on Saturday, and instead of a TP ran a Helix HFC. Was fine Saturday, did not drive Sunday, and took it to work this way and 2 miles out the door...service engine light...GRRR.
Well, guess I will go with the spark plug fouler remedy. I assume that is what is recommended? And I am running a boost gauge but no MBC but I rarely floor my car so not really worried about over boosting. Pulled the code...it says insufficient catalytic converter.
Old Jul 23, 2007 | 05:11 AM
sharkm87's Avatar
fouler ftw!...tbe w/tp...never had an issue.
Evo Girlie's Avatar
don't they claim to not throw a code at all??? I would double check on that and ask the vendor directly
Old Jul 23, 2007 | 05:16 AM
joey0480's Avatar
well i got the cat from a member, he said it was all good, no issues. Should i try resetting the ECU? in regards to that, I have a question. Now with my previous truck, the method of resetting the ECU was pulling a certain fuse, and turning it on till 3 chirps.
how do you reset the ecu on the evo?
Old Jul 23, 2007 | 05:21 AM
mifesto's Avatar
HFC can still throw you a CEL.... happened to mine once in awhile
Old Jul 23, 2007 | 05:23 AM
Evo Girlie's Avatar
Try disconnecting the battery first for a few minutes then put ut back and turn car on see if that helps. If not u can tk it to pep boys or local shop they pull the code for u for free and can tk it out also
Old Jul 23, 2007 | 05:26 AM
whoang40's Avatar
don't just try to reset the ECU. That's covering the problem, not fixing it. Read the code and post it on the forum. Like they said a HFC will bring you a code error, but if its another error you'll never know whats happening to your precious engine. Good luck.
I had my check engine light come on once in awhile after the UR test pipe. I did what you did and it kept coming back. Found out that I was running lean. Added a fuel pump and did a custom tune, never seen it come back at all. Good luck bro!
Old Jul 23, 2007 | 05:31 AM
cheb evo's Avatar
Here you go...$5 in parts and 10 minutes in labor...
https://www.evolutionm.net/forums/sh...mechanical+fix
Old Jul 23, 2007 | 05:35 AM
joey0480's Avatar
well, i think there is an autozone two miles from where I work so I am gonna stop there on the way home and see if they can check it out. Also gonna call the place that put the exhaust on and ask him about it...since I have to get some longer bolts anyways when i go back to him to put those thingys back on lol
Old Jul 23, 2007 | 07:09 AM
joey0480's Avatar
is it all autozones that check codes? and will the fouler definitely work or am i better going with a O2 eliminator? Just asking before making any decisions.
Old Jul 23, 2007 | 12:15 PM
sonicnofadz's Avatar
I run a test pipe, and no defoulers. I also don't run the cel fix or anything to trick the O2 sensor at all. For some reason I just don't seem to throw a code? I still have it plugged in too!
Old Jul 23, 2007 | 05:53 PM
joey0480's Avatar
damn that must be nice, my HFC stinks already
Old Jul 24, 2007 | 01:57 PM
qwon526's Avatar
i have a testpipe w/ a bung welded for the o2 sensor and no CEL for that. I just recently started getting a CEL for the front sensor heater circuit, whats strange is after re-connecting battery it stays off for about 500 miles than the CEL pops up again.
I would pull the code first to make sure its the rear o2 sensor and get the fouler if it is.
Old Jul 24, 2007 | 02:49 PM
Jakeg97's Avatar
should have went with a random tech hfc
i have one and the light does not come on
Old Jul 24, 2007 | 02:56 PM
Jakeg97's Avatar
definitely work
https://www.evolutionm.net/forums/sh...d.php?t=114931
O2 eliminator is a waste of money imo
