Evo ix ?
Old Aug 8, 2007 | 09:55 AM
augosta's Avatar
Evo ix ?
Hi everyone
Can I increase the boost to 22 or 23 psi with stock fuel pump on an Evo 9?
Other mod. Intake, exhaust, ported manifold
I would like to increase the boost before tuning
thanks
Old Aug 8, 2007 | 10:18 AM
Chemwarrior's Avatar
In a word, yes. Just keep in mind that you will yield better results after the tune.
Old Aug 8, 2007 | 10:21 AM
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
https://www.evolutionm.net/forums/search.php
Old Aug 8, 2007 | 10:43 AM
Turbo Kyle's Avatar
You should be fine the IX pump is better than the others.
Old Aug 8, 2007 | 11:40 AM
CrackerJackToy's Avatar
Yes you will be fine. Look into getting a 255 walbro though, for insurance.
Old Aug 8, 2007 | 01:36 PM
It's not a necessity to get a 255 since he already has the IX FP.
Old Aug 8, 2007 | 01:38 PM
tolga900's Avatar
walbro 255 only answer
Old Aug 8, 2007 | 02:39 PM
WWNJIX's Avatar
Play it safe= Walbro
Old Aug 8, 2007 | 03:32 PM
B0ostedFr34k's Avatar
since when is the walbro not a good idea? IX stock FP cant be as strong as the 255 i say, 80 bucks play it safe or dont and take it in the rear when something messes up
Old Aug 8, 2007 | 04:02 PM
lemmonhead's Avatar
since your planning on doing those mods, might as well get the pump so you can increase boost to 25 if you wanted. but at 22 your fine dude, not necesary.
Old Aug 8, 2007 | 04:08 PM
Nauticabri's Avatar
You dont need the pump on a IX for 22-23psi... Sure you could get it for insurance but it is not needed unless you're pumping up the boost 25+psi. On 8s you do on 9s you dont.
Old Aug 8, 2007 | 05:18 PM
97TSiAWD's Avatar
For less than $100 and an easy installation, it's worth it to change the fuel pump before reflashing. It's a few bolts, quick disconnect fuel lines, and clips to install it. Compare that to the headaches it is in DSMs (hard lines that usually break) or MKIII Supras (have to drop the fuel tank), and it becomes an easy choice.
Old Aug 8, 2007 | 06:12 PM
JDMCT9MR's Avatar
I ran my car for a while at 23 psi before getting a walbro fuel pump.Like everyone says you'll be fine with the stock one but better safe than sorry.
Old Aug 9, 2007 | 03:47 AM
augosta's Avatar
OK that was sufficient for me thank you everyone you are all masters of EVO
