to anyone with greddy boost gauge
does any one have the new greddy boost gauge 52 mm (amber light)in here, and if you do how do u like it. mine does not show any vacuum for a couple of minutes after engine is at normal temp and i stop and start the car again. it does not do this when engine is cold on first start up.
Mine doesn't do that either...it shows vacuum right when I start the car. I've got my gauge tapped at the fuel pressure regulator solenoid. Vacuum hose runs from there to the sender, and then the wire from the sender to the gauge. (It's an electric gauge, not mechanical) Here's a link with a picture, second one down.... http://evomoto.com/tech_info.php?tPa...fb82ae747ef3fe
