Gas gauge doesn't work, stuck
Old Aug 28, 2007 | 05:35 PM
bolio's Avatar
My gass gauge is stuck at half a tank. I took it to the dealership and they checked everything and concluded that it was the cluster and ordered a new one under warranty. I got the car back today and went to fill the tank and guess what, it's still stuck at half a tank. Any ideas what censors, computer, wires or connections I can tell them to check since they don't seem to have any idea how to fix it? Has this happened to anyone else? It sucks not knowing exactly how much gas you have in the tank.
Old Aug 28, 2007 | 05:39 PM
evillancer06's Avatar
Veteran: Navy
help
did you do any mods to the car. if you installed a fuel pump you might have not connected everything correctly.
gsrboi80's Avatar
Its likley the float in the tank and not in the cluster
Old Aug 28, 2007 | 05:41 PM
ak47po's Avatar
Could be the float in the gas tank.
Old Aug 28, 2007 | 05:50 PM
bolio's Avatar
The car is and always has been 100% stock. How do you go about fixing the float problem if that's what it is, is it a PITA?
Old Aug 28, 2007 | 07:00 PM
gsrboi80's Avatar
You'll need to remove the fuel pump assembly and check it out. It may either be stuck in a fixed position or faulty.
Anyways It takes about 10 min to remove the assembly. Pop the bottom (bench part) of your back seat out and you'll see the circle of screws holding in the assembly on the drivers side.
Old Aug 28, 2007 | 07:22 PM
Evoluvin's Avatar
its mos tlikely the float
Old Aug 28, 2007 | 07:31 PM
whoang40's Avatar
Just upgrade to a Walboro while you're at it. The float is your fuel level sender to your gas gauge. Take that stock one off, and since you're there switch it out to a 255 Mitsubishi techs. don't know shee***t.
Old Aug 28, 2007 | 07:38 PM
BluEVOIX's Avatar
Probably the float. I always fill up from 3/4 tank full and occasionally from the 1/2 tank mark. So once or twice after filling up it took about 5 minutes for the gauge to read full tank. I guess the float was getting stuck, but that was a while ago and it hasnt happened again.
Old Aug 28, 2007 | 08:00 PM
Jakeg97's Avatar
+1
glad to see your dealership is on top of things....
Old Aug 28, 2007 | 08:04 PM
4WS Tuning's Avatar
dont upgrade to a walbro.... hes stock and its not necessary on an 8 til you install cams.
www.evomoto.com
There is a write pictures on there.
Cheers!
Old Aug 28, 2007 | 08:10 PM
Jakeg97's Avatar
www.evomoto.com
Cheers!
true , but if he is taking it out, might as well replace it with 255 that is cheap and will need later on anyways
http://evomoto.com/tech_info.php?tPa...2d50f5d386116f
Old Oct 20, 2007 | 12:19 PM
trinydex's Avatar
so how does the float get stuck?
Old Oct 20, 2007 | 12:23 PM
suprawillis's Avatar
I have had floater issues as well. Mainly on the passenger side floater. I have a new one on the way to see if that solves any problems. Keep us posted if you get it fixed because I have the same problem.
Old Oct 20, 2007 | 01:14 PM
BOOSTEZ's Avatar
Agreed. Might as well change out the fuel pump to a 255. It won't give him any more gas than his motor already demands.
-M
NocturnalEVO
Dec 7, 2018 04:47 PM
Evolved-8
Oct 30, 2013 05:57 AM
krafty
Oct 17, 2010 04:47 PM
Carrier
Lancer Troubleshooting
18
Aug 8, 2007 01:56 PM
BlueEvo04
Oct 12, 2004 10:30 AM
