Help!! Something always goes wrong during my installs!!
Hey guys im currently installing a blitz TT DC4 into my car and have everything hooked up except the e-brake wire. I turn the car on and the tt turns on perfectly...but one problem..when i turn the car off the car doesnt stay on!!! lol what can it be? the unit obviously turns on ok..do i need to find a better ground? or do i need to hook up the e-brake wire? is this unit defective
any input would help thanks!!
When the e-brake wire is connected and you engage the e-brake, that wire is grounded. When you let off the e-brake, that wire is no longer grounded and the car shuts off. You either need to connect that wire to the e-brake or you need to connect it to a ground.
-Paul
-Paul
if you can hook the harness up then theres no reason why you shouldn't have the e-brake wire hooked up.
https://www.evolutionm.net/forums/sh...d.php?t=292220
theres a write up I made how to do it.
u need to have it hooked up if you dont then someone could in theory take your care for a joy ride. they could just keep upping the time on the TT tilll there done. when you disengage the E brake is when the care will shut off preventing from anyone jacking your care while the TT is running.
-Paul
