what to do with that "lancer thing" on guages???
Old Oct 11, 2007 | 10:11 AM
JJsEvo8's Avatar
Wow, sweet gauges!
How does the power hookup for the Trustz work? Did you need a vampire tap or anything?
Old Oct 11, 2007 | 10:52 AM
TempeRacerGuy's Avatar
The overlays that are just above I would be weary about... how dim are they at night now.
I have the Trustz gauges, They are EL gauges, so they have their own light source and can be extremely bright.
I got the blue gauges, to match my blue 60mm Link2 gauges in a rexpeed pod.
They install over the needles because the center opening is slightly larger than the needle base.
2 suggestions:
1: dissassemble the LED, scrape the red off of the diffuser pannel and replace with a blue plastic gel, or no gel if you are using the white gauges from trustz
2: do not use the overlays that go over the turn signal portions... they will just make your turn signals dimmer.
The trustz gauges need a power source. I soldered/heat shrinked in the power source / ground into the dimmer switch. This way when the headlights go on, the EL gauges light up.
I am very impressed with my dash so far
Austin T
Old Oct 12, 2007 | 11:42 AM
tommyevo's Avatar
Actually, I pulled off the condoms on the bulbs and everything is brighter than stock
Old Oct 12, 2007 | 11:52 AM
dodgecoltracer's Avatar
tommyevo, how do they look at night... maybe a pic ??
Old Oct 12, 2007 | 11:57 AM
tommyevo's Avatar
I'll get one for you tonight and post Monday
Old Oct 12, 2007 | 12:01 PM
tommyevo's Avatar
Here's the link, they can put anything you want on the faces, check out some of there custom stuff.http://blackcatcustom.com/Evo%20VIII%20&%20Evo%20IX.htm
Old Oct 12, 2007 | 12:17 PM
tnhockey's Avatar
damn dude those trustz overlays look siiiick. but yea how would the 180 mph work??
Old Oct 12, 2007 | 01:00 PM
YtDiamond05's Avatar
^^ +1
Old Oct 12, 2007 | 07:32 PM
LoCo4's Avatar
DOn't know......haven't taken it that fast.
Old Oct 14, 2007 | 07:38 PM
trboboost91's Avatar
those look nice and all but i want to turn that word into somekind of guage not just make it read something else like "evolution" or "evo VIII".
nice guages though!!!
Old Oct 14, 2007 | 07:50 PM
Originally Posted by Evo_Kid
I saw someone make it so a digital readout for AFR took up that area. search
what did you type in the search field? tried to search but came up with nothing!
Old Oct 14, 2007 | 08:22 PM
ImJoey's Avatar
Originally Posted by tommyevo
Blackcatcustom did this to mine, about $75.00
Ewww...
Old Oct 16, 2007 | 03:53 PM
^^^^^^ +1
Old Oct 16, 2007 | 09:44 PM
Evo_Jay's Avatar
look in the how to sections. its in the first 15 or 20
Old Oct 17, 2007 | 05:06 AM
04KWAK636's Avatar
I don't think the white and red look that bad.
