Turbo xs downpipe
Old Oct 28, 2007 | 10:35 AM
destro92179's Avatar
Turbo xs downpipe
So I was installing the downpipe and noticed there is a gasket to connect to the cat but no gasket for the turbo end. Does anyone know if it is suppose to come like this.
I have already installed the part and thought there was a leak. I could here something new coming from my motor and realized it was my turbo spooling up faster My boost gauge still hits about 19 psi and feathers down to like 15-16 up to redline.
Old Oct 28, 2007 | 10:46 AM
DG Motors's Avatar
you should be able to use your existing gaskets....
Old Oct 28, 2007 | 01:55 PM
my stock downpipe didnt have a gasket at the turbo end. I thought that was very weird but judging by my boost gauge it doesn't seem like there is any leaks. with a downpipe and catback will I need a lvl colder spark plugs or a boost controller? Or is my car ok the way its runnin?
Old Oct 28, 2007 | 02:05 PM
EvoDom's Avatar
i have never herd of that....there shoulda ben a gasket....check ur exsisting down pipe to see if the gaskets there...but if theres no leak then u should be alright as long as ur boost is fine and ur not loosing power u should be ok
Old Oct 28, 2007 | 03:26 PM
DG Motors's Avatar
no you do not need colder plugs. Since you do not have a signature i can not tell you to buy a boost controller. If i were you, i would buy a drop in filter, hfc/test pipe, boost controller. Then get a tune.
Old Oct 28, 2007 | 03:28 PM
AndyBandy's Avatar
should be just a donut gasket...right?
Old Oct 28, 2007 | 08:29 PM
took your advice and just got a mbc, flash, and evo 9 bov....I've made a lot of new friends with evo's and they hooked me up all this for 80 dollars.....
too bad my girlfriend is upset now
Old Oct 29, 2007 | 04:39 AM
DG Motors's Avatar
good choice
Evo47
Jun 23, 2016 10:39 AM
SamTrippyMan
Aug 17, 2015 10:52 AM
kozmic27
Jun 28, 2009 11:38 PM
mugen777
Mar 12, 2009 06:54 AM
NYREDEVO
13
Nov 11, 2004 06:14 AM
