GAUGES help please.
Old Dec 9, 2007 | 04:11 PM
binhtran's Avatar
GAUGES help please.
i have a 03 evo my temp. gas. and lancer lights are off can this be a fuse? but the gauges still works just no light
Old Dec 9, 2007 | 04:48 PM
596736's Avatar
sounds like an obvious fuse issue
Old Dec 9, 2007 | 04:49 PM
shurikss's Avatar
dimm. lights or actual lights ??
Old Dec 9, 2007 | 04:53 PM
kaonashi's Avatar
he's probably refering to the dash lights, look in your manual for the fuse's and change them out they should all run on 1 fuse.
Old Dec 9, 2007 | 07:08 PM
binhtran's Avatar
thnx for the reply ill check the fuses.
Old Dec 9, 2007 | 07:13 PM
wizzo 8's Avatar
Sounds like the bulb burned out. Take the cluster out and replace the bulb. I really dont think its the fuse.
Old Dec 9, 2007 | 07:25 PM
LoCo4's Avatar
Check the fuses first (easiest option). If everything is in order pull out the cluster and check the bulbs.
bwanner
Jan 13, 2012 01:01 PM
smoke
May 12, 2009 10:57 PM
SmoothRA04
Jan 20, 2008 09:17 PM
BOOSTEZ
Oct 19, 2007 08:05 PM
ApexVIII
11
Apr 24, 2007 12:13 PM
