clutch pedal question helpp
Old Dec 17, 2007 | 07:47 PM
itzcharlez's Avatar
i drive a 06 MR
have about 13k on the odometer and never changed the tanny fluid..
never raced or tracked.. regular normal driving
recently it have gotten a bit more notchy shifting from 1st to 2nd on slow shifts....
any ideas on how to solve this?
would changing the fluid solve this?
i've heard of adjusting the clutch pedal but i dunno..
would that solve it?
which way do i adjust it?
help?
Old Dec 17, 2007 | 07:51 PM
t51splbb's Avatar
Look no further than the "how to" section.
https://www.evolutionm.net/forums/sh...d.php?t=260040
Old Dec 17, 2007 | 07:55 PM
ray3328's Avatar
does it still feel notchy after the trans has warmed up?
Old Dec 17, 2007 | 07:57 PM
itzcharlez's Avatar
i'm not asking how to adjust it.. i'm asking if i should..
and to answer your question... after its warmed up it gets better.. but is still present at times...
it seems to go in smooth when i shift faster...
Old Dec 17, 2007 | 07:58 PM
huevosrancheros's Avatar
Time to replace the tranny fluid
Old Dec 17, 2007 | 08:00 PM
ray3328's Avatar
Then it's normal, nothing to worry about.
Old Dec 17, 2007 | 08:03 PM
ray3328's Avatar
not really... he said it's been normal driving so the fluid should be ok, I think it's due to the temperature drop
Old Dec 17, 2007 | 08:05 PM
itzcharlez's Avatar
rarley but sometimes it feels like a slight grind going into second thus raising my concern...
i know i need to change the fluid.. its time..
Old Dec 17, 2007 | 08:14 PM
ray3328's Avatar
Do you feel a grind or is it notchy when cold? After the trans is warmed up do you still have these issues?
Old Dec 17, 2007 | 08:23 PM
itzcharlez's Avatar
like i said it gets better... but its still there.. its wierd.. its on and off too.. like some days will be better than others..
stock clutch..
Old Dec 17, 2007 | 08:28 PM
itzcharlez's Avatar
hey i noticed you lived in LI..
i live in Li too lols right off DPA
i'm not too sure what it is.. it might be temperture drop..
does the clutch ever go "out" of adjustment? like i would have to adjust it?
Old Dec 17, 2007 | 08:39 PM
ray3328's Avatar
As the clutch gets worn it will need adjusting so you can first try that. Then let the trans fluid warm up before you get on it. Grinding is never a good sign though. If after you adjust it it still grinds you can try changing the fluid. If none of those work you might eventually be looking at a rebuild.
Old Dec 17, 2007 | 09:21 PM
itzcharlez's Avatar
hemm thats a good idea.. which way should i be adjusting the clutch pedal? up or down? lols
by the way how long after first starting the car would you say it takes for the tranny fluid to warm up?
