need some help, wierd sounds
Old Jan 20, 2008 | 11:20 AM
gottf257's Avatar
recently i installed an ams 3" downpipe, and the ams 3" testpipe onto my ams 3" catback onto my Evo 9. ever since we installed it i get a wierd metal and metal sound, almost like a klunk whenever i start in first gear or when i come to a complete stop (pretty much whenever the weight of the car shifts). i got underneath the car again and all bolts were tight and the exhaust seemed solid. i also have recently gotten an OEM clutch installed by mitsubishi on my car as well, since i burned through the first. any ideas to whats causing the sound?
Old Jan 20, 2008 | 04:40 PM
Jameson_IXMR's Avatar
There is a metal fram (a heat shield) that follows the exhaust, it is bolted to the car not the exhaust. Anyway it starts about where the stock cat would be and goes back. It is flimsy as hell and could be it. Other than that remove your crossbars and see if that removed the problem, then you need to space them to reinstall. It might also be the pipes hitting the frame or various engine components. The exhaust system moves alot forward and back.
I would suggest you look at the heat shield. Especially the section that sits over the flange for the cat/DP connection.
Old Jan 20, 2008 | 04:48 PM
03RRVIII's Avatar
check the gap beetween the downpipe, crossbar, ACD, subframe, & oilpan. those are the common spot where the downpipe could hit, especially when the are 3" in diameter.
austin_davee
Oct 2, 2016 09:18 AM
Evolution8RS
Sep 13, 2008 12:04 PM
amscrazy
Dec 5, 2007 02:26 PM
WickedIXMR
Jan 24, 2007 12:43 PM
evobeatsti
Sep 19, 2006 03:16 PM
