Evo 8 wiring harness diagram?
Does anyone have a wiring diagram for the evo 8 harness? I just bought a evo 8 and this wiring harness is a mess. I found where most of the plugs go however there are a couple that I am trying to figure out.
Thanks in advance!
2 wires in particular I am looking for.
-Power steering (Blue wire)
-AC compressor plug (circle plug)
Thanks in advance!
the red and white on injector 2 is positive as well as the green on injector 3. the red on injector 4 is positive and orange is positive on 1. look at the positive on the other clips that I just described and see what side of the clip they go in
05EV08 (Apr 30, 2016)
Any idea what these 2 are?
Obviously one is power steering and the other is AC compressor but I can't find what plugs into them.
they both come off of the fender harness, the two plugs coming from the valve cover should be the crank angle sensor and the front o2 sensor
only way to tell for sure is to pull the harness apart and look for cut wires but even then you wont have the plugs. hate to say it but you might want to get a new harness if this much is missing from it
Does anyone know what color the wires are so I can figure out which one goes where as mine dont have connectors on it anymore.
I wonder who the previous owner was that did this...
The following 2 users liked this post by ISPEVO8:
05EV08 (Apr 30, 2016),
uneekvisions (Jan 30, 2023)
