Rear Shock Bolt!!! Help Me!!!
Old Jan 28, 2008 | 05:35 PM
bboy_RES's Avatar
i'm trying to install my Swift Mach Sport MR Springs, but the rear shock bolt seems impossible to remove! i tried using a 17mm socket and a breaker bar, but the socket broke! it split in half or something. i tried using another 17mm socket, but that socket started getting stripped! what am i doing wrong? should i use the socket on the nut side or the bolt side of the shock? i just sprayed the bolt with pb blaster so i'll see if that helps. i wanna try to finish this tonight! thanks.
Old Jan 28, 2008 | 05:39 PM
gsrboi80's Avatar
Yea they get siezed up pretty good sometimes. Air tools usually help out alot. See what the PB Blaster does and if not try and heat it with a torch if you have one
Old Jan 28, 2008 | 05:40 PM
bboy_RES's Avatar
haha i'm gonna head to autozone to buy a new 17mm socket and i'll buy a lighter as well. that'll work too right? as long as the bolt is heated. haha.
Old Jan 28, 2008 | 05:43 PM
gsrboi80's Avatar
You'll never be able to get it hot enough with a lighter you'll burn you thumb first. They sell cheap torch kits there pick one up. They'll always come in handy down the road.
Old Jan 28, 2008 | 05:44 PM
bboy_RES's Avatar
i'll see what i can find. hopefully this works. thanks.
Old Jan 28, 2008 | 05:57 PM
krazirob's Avatar
Lol.....
Old Jan 28, 2008 | 07:09 PM
bboy_RES's Avatar
okay so that didnt work. i tried using a torch and that didnt work either. i might need another set of hands to help me. i'm gonna try more pb blaster one more time and see what happens. this is harder to take off than the cam gear bolt!
Old Jan 28, 2008 | 07:47 PM
90GSX-03EVO's Avatar
Impact ratchet.
Old Jan 28, 2008 | 08:12 PM
edmundo's Avatar
I am sure that you are loosening the nut in the correct direction, counterclockwise. Try spraying some Gunk liquid wrench on the bolt thread and let it sit for a while. Then use a long breaker bar on the nut and have a friend or significant other hold the bolt with a wrench to stop it from turning. That should be enough.
Old Jan 28, 2008 | 08:28 PM
bboy_RES's Avatar
okay i got it! i dunno what i did, but i got it! i dunno if it was the crap load of pb blaster i sprayed on it, but it finally came loose! i was always able to spin the bolt (the nut would spin with it so i wasn't loosening it). i was spinning the bolt so i could fit a wrench on the nut and i felt it come loose! i hope it's not this hard on the other side! thanks for the suggestions guys.
Old Jan 28, 2008 | 09:07 PM
kuo246's Avatar
i never use sockets when breaking bolts i would always use wrenches but congrats on getting it off, its a great feeling no pun intended
Old Jan 29, 2008 | 12:13 AM
bboy_RES's Avatar
haha okay now the other side seems impossible. it feels like the bolt is breaking loose, but it's not! the bolt is getting stripped because the socket keeps sliding off. i dont want it to get stripped to the point where i cant even use the socket anymore.
Old Jan 29, 2008 | 12:16 AM
HiatusMotorSprt's Avatar
Use a Air wrench. Just make sure you torq. it to the appropriate specs so you dont run into this again.
Old Jan 29, 2008 | 12:42 AM
bboy_RES's Avatar
yeah i gave up trying to do it with a breaker bar. i dont wanna strip the bolt. i'm gonna see if i can borrow or rent an impact wrench from someone/somewhere. does autozone rent out impact wrenches?
Old Jan 29, 2008 | 12:45 AM
bboy_RES's Avatar
i dont know much about impact wrenches, but is 230 ft.lbs. of torque enough to break the nut/bolt loose?
