New(ish) Evo IX, squeaking brakes at low speed
Old Jan 30, 2008 | 10:53 AM
SurferX's Avatar
I ended up finding and buying a used 06 Evo with only 2k miles on it. My brakes will begin to squeak at very low speeds when coming to a stop after the car has been driven a bit. I wanted to know if this was normal for the stock Brembos and pads, as I know high performance brakes can do that at low speeds, or if I should take the pads out and check them out.
Also does the Evo IX come stock with Brembo pads (which ones if so) or do they just have the calipers with some other type of factory pad in them?
Old Jan 30, 2008 | 10:59 AM
CRX2EVO's Avatar
https://www.evolutionm.net/forums/sh...+brakes+squeek
Learn to search and post in the correct forum. You think you're the first person to ask this question?
06MRV8Killer's Avatar
completely normal
Old Jan 30, 2008 | 11:00 AM
Evo9"Miss Rose"'s Avatar
no they only come with brembo pads stock no aftemarket unless changed by someone part#MR407376 (Stock brake pads if that helps you)
Old Jan 30, 2008 | 11:55 AM
SoundBoy4's Avatar
perfectly normal, enjoy the evo.
Old Jan 30, 2008 | 12:37 PM
Guz Man's Avatar
+1
had the sqeak the second day i bought my evo, dropped it off at the stealership, next day they said "its perfectly normal.. unfortunately we cant find a fix for it, but if it does happen again, please come back"
and i am like.. why would i come back, so u can tell me to come back again?
so the squeaking got lesser and lesser with time, and i ended up changing my whole break system.. no squeak what so ever..
have fun with your evo man..
Old Jan 30, 2008 | 05:31 PM
dan nguyen's Avatar
It's normal for an EVO. mine does the same, some day you hear it ,some day you dont..
Old Jan 30, 2008 | 06:02 PM
evo8426's Avatar
its normal and mine usually will only do it in cold weather
Old Jan 30, 2008 | 06:10 PM
Kdash106's Avatar
normal. just enjoy the car, and congrats.
Curt@MrLed's Avatar
Former Vendor
try rebedding them.
Old Jan 30, 2008 | 06:30 PM
JDMCT9MR's Avatar
The guy just got the car so give him a break.I'm sure that you came to EVO M with questions as well when you first got your EVO.Besides, this is a general forum and this sounds like a general question. Be helpful and show some respect.
Old Jan 30, 2008 | 06:36 PM
godmiller10's Avatar
ya mines been doing it since i got it. Really annoying but it does not mean your brakes are bad so your good, enjoy.
Old Jan 30, 2008 | 08:39 PM
CRX2EVO's Avatar
there is a Tires, Wheels, BRAKES, Suspension section smart guy
Old Jan 30, 2008 | 08:50 PM
JDMCT9MR's Avatar
True as that may be the guy was just asking for help.Would you want someone to respond with such a negative comment as yours?
Old Jan 30, 2008 | 08:54 PM
eponti's Avatar
Evo squeaks,whines and notchy.Normal
