Throwin codes CONTINUOUSLY!
Old Mar 4, 2008 | 06:23 PM
4rcd6's Avatar
So here's my deal.....
In WI they have a summer mix and a winter mix of gas but they don't say that at the pump so its usually not much of a difference; however I keep throwin codes along with my best friend who also has a IX SE with similar mods. The codes we both throw can be reset but start the car... turn it off... then restart it automatically trips the same codes again. Only have had this issue once the temps got cold which is usually when the gas mix changes so I've heard.
P0037 - H02S bank 1 sensor 2 heater circuit low
P0138 02 sensor curcuit high volts (bank 1 sensor 2)
Any one having a similar issue and if so why the heck are these codes continually tripping?
I'm trying to see what it is that's causing the codes to trip.
I've searched and haven't ran across anyone yet mention so I'm hoping I hear something from someone.
Thanks!
Old Mar 4, 2008 | 10:07 PM
personal_golf's Avatar
Veteran: Air Force
If you're both throwing the same codes...could be the gas.
Old Mar 19, 2008 | 07:32 PM
4rcd6's Avatar
i suppose but it seems wierd that others aren't getting it if it was the gas. anyone else heard anything on this?
Old Mar 19, 2008 | 08:29 PM
M5K15's Avatar
Never saw either those codes before.
I've only ever thrown P0420, which was just my post cat censor telling me the high flow wasn't cleaning ****
But since it's the voltage, did you install/mod something that's maybe shorting out one of the wires? Or left a piece of wire bare?
Old Mar 20, 2008 | 09:32 AM
saucemaxx's Avatar
I have been running on 93oct from BP/Amico and I have not seen those codes
Old Mar 27, 2008 | 11:02 AM
PureDsm's Avatar
sounds like gas
Reminiscence
Dec 8, 2019 10:36 PM
Dwilson36
May 5, 2016 11:05 AM
campbmic
Lancer Engine Tech
18
Mar 16, 2015 09:17 AM
soclancer
Lancer Engine Tech
24
Jul 3, 2014 08:38 AM
raasfaas
Jun 24, 2009 10:02 PM
