Bad News After Installs!
On Wed. I had a Prosport Boost, Oil Pressure, Water Temp gauges as well as a Forge UNOS boost controller (it is on its first click) at a local shop. Since the install the car bucks horrifically while running throw 2nd gear at about 5k. And the Service Engine Soon Light is on now as well! Help me please I cant wait till Monday to go there, the IX is my DD.
Thanks,
Jay
Thanks,
Jay
the UNOS controller takes a lot of clicking to get the PSi at the desired level. I fudged with mine today and turned it atleast 4 full turns (like 20 clicks) and it only dropped to 17psi and I usually run 21-22. Sounds very odd could the shop who installed it taken it for a drive and ruined your transmission?
Or just a improperly installed boost controller when it bucks is it making boost up to 5k?
Check the vacuum lines at left side of the intake manifold to see what they screwed up... are you having breakup problems when in boost or is it running like crap completely, even at idle/cruise ?
Get the code scanned, that will probably tell you what the problem is, but my guess is a botched boost gauge install.
