My dyno tune results...
Old Apr 6, 2008 | 05:11 PM
MR Dan's Avatar
My evo 9 was retuned over at Harman Motive's facilty here in Torrance, CA. Thanks to Scott Barbour for his superior tuning skills
Mods: Tomei exh. manifold+DP+O2 housing, Fujitsubo exhaust w/ muffler delete, LICP, Apexi cone filter, HKS intake box, RC750cc injectors, Walbro 255FP
Results:
295WHP
287Ft/lb TQ
Mustang dyno reads anywhere from 11% to 15% lower correct?
Old Apr 6, 2008 | 05:28 PM
AznEvoIX's Avatar
295 HP and 287 TQ. Nice. I'm stock. =P
Old Apr 6, 2008 | 05:33 PM
evokel's Avatar
im not really sure, but when i had the same mods i had 330whp. on a mustang dyno?
but good numbers by the way!
Old Apr 6, 2008 | 05:35 PM
Thegame's Avatar
Those numbers are pretty good. Don't worry about comparing other people's numbers to your own. They will always vary. Did you by chance get a baseline on that same dyno?
Old Apr 6, 2008 | 05:42 PM
importjake00's Avatar
Not bad bro! for some reason i really like those wheels....... there awesome!
Old Apr 6, 2008 | 05:43 PM
IXmr321's Avatar
+1....comparing before and after is what really matters. Making sure you are gaining the correct HP aand TQ from the mods
Good numbers!
Old Apr 6, 2008 | 06:10 PM
SickSilverNLow's Avatar
not bad.....pics of the car please..looks great from the dyno shot, specs on wheels too .
Old Apr 6, 2008 | 06:36 PM
tony_b's Avatar
I put down 279 on Buschur's Mustang dyno with pretty much an exhaust, drop in and a base E-Flash from Al.
Old Apr 6, 2008 | 07:03 PM
red evo8's Avatar
dynos are bragging rights short lasted ... time slips are for ever
Old Apr 6, 2008 | 07:07 PM
MR Dan's Avatar
Good numbers!
The car ran like crap after i installed the injectors so the tuner had to scale them and started tuning immediately without a baseline run.... but the overall power gains i felt on my butt dyno is remarkable.
Old Apr 6, 2008 | 07:17 PM
Flyin EVO 2's Avatar
What's the weight of those wheels vs. stock? Heavier wheels and/or break rotors rob power as well.
Old Apr 6, 2008 | 07:22 PM
MR Dan's Avatar
The WORK Meister 2 piece 18X9 weighs 20lbs... I believe the stock BBS are about 17.5lbs?
Old Apr 7, 2008 | 05:28 AM
urslo4n8's Avatar
Good numbers for a mustang dyno! dynojet should be almost 20% more
Old Apr 7, 2008 | 06:08 AM
evogottago's Avatar
Basically same mods (plus cams) I was making 330whp on Buschur's dyno.. but if the car feels alright, then it's all good. Plus you're in cali so you're prolly running 91oct I'm guessing...
Old Apr 7, 2008 | 06:16 AM
Burklow's Avatar
I like that quote.
You're numbers are pretty good for the dyno. If you want bragging numbers, go use a dynojet.
