AEM wideband stuck at 14.8
Old Apr 7, 2008 | 08:55 PM
MR06Evo's Avatar
I just installed my aem uego wideband today and it stays stuck at 14.8. I bought the wideband brand new from one of the vendors on the forum. I have tried disconnecting the harness to the 02 and have rechecked my connections a few times. Also there is like some calibration screw in the back of the gauge, could that have anything to do with it.
Any ideas on what could be going on?
Also I did do some searching before this but most people had this issue with older 02's not brand new ones.
Thanks!
Old Apr 7, 2008 | 09:34 PM
quick silver 8's Avatar
sounds like something is not connected right
Old Apr 7, 2008 | 09:56 PM
inco9nito99's Avatar
For the most part, there is no calibration on the UEGO unit.
Old Apr 7, 2008 | 10:38 PM
ImJoey's Avatar
Mine got stuck once and I unscrewed the o2 sensor and sprayed the hell out of it with electronic parts cleaner.Screwed it back in problem solved.May not work but its another shot in the dark.
Old Apr 8, 2008 | 07:42 PM
MR06Evo's Avatar
BUMP-
So I took a look at the 02 today and it seems to be rubbing against the floor of the car. I got the bung welded too close to 1 o'clock instead of closer to 3. It was a pita to put in because I had to pry the downpipe to even get it to fit. I think in this process I might have messed up the actual 02 sensor.
Is it that sensitive that from it getting pinched would cause it to not read at all??
lemmonhead
Jun 18, 2025 01:51 PM
Junkyardspecial
Aug 11, 2015 06:23 PM
Pudge23
Jun 6, 2014 09:59 AM
LivinloudEvo
Jan 31, 2011 03:43 PM
NYEvoguy
Jan 25, 2008 12:01 PM
