Whining?
Old Apr 20, 2008 | 05:23 AM
personal_golf's Avatar
Veteran: Air Force
Whining?
I recently had an ACT clutch and flywheel installed. Great installer...then a very small continuous whine started. Sounds like a aftermarket Walbro pump wine near the back wheels...but the funny thing is...I have a stock fuel pump Strange, any ideas what it could be? Doesn't bother me really, just making sure it isn't anything related to my car breaking or a safety issue. Thanks for your help!
Old Apr 20, 2008 | 05:27 AM
assembeldbygod's Avatar
It might be your transfer case going bad. My cousin has a act clutch in his car and their is no whine except from the walbro pump.
Old Apr 20, 2008 | 05:30 AM
Veteran: Air Force
not the same whine as the transfer case...very mild compared to the TC whine. Also whine is from the back of the car...now, unless some leprechaun decided to gift me with a Walbro...pretty sure it's stock. Sounds EXACTLY like the 255 pump's whining. Weird...any ideas?
Old Apr 20, 2008 | 05:32 AM
What model act clutch?
Old Apr 20, 2008 | 05:35 AM
Veteran: Air Force
Heavy Duty Street
Old Apr 20, 2008 | 06:11 AM
smokedmustang's Avatar
At what rpm/boost level do you hear it?? my TC went bye-bye 100 miles after a clutch install. when do you hear the noise?
Old Apr 20, 2008 | 06:21 AM
urslo4n8's Avatar
Stock fuel pump going bad possibly?
Old Apr 20, 2008 | 07:59 AM
rcheung's Avatar
Post a clip of the noise.
Old Apr 20, 2008 | 10:43 AM
Veteran: Air Force
It's just when it idles...it's so faint you can't hear it at all when driving. Just sitting there at idle outside of the car, like I said before sounds exactly like a Walbro pump whine...weird cause it's a stock pump.
Old Apr 20, 2008 | 01:36 PM
Veteran: Air Force
The whining just stopped when I went out today...I failed to mention that I changed out the perrin turbo back for the stock just for inspection two days ago lol then changed it back...the gaskets were shot so I used that copper rtv sealant as "gaskets". It didn't "cure" entirely...actually to be honest I drove it right away, do ya think some air was escaping and now that the sealant is fully dry the whining is gone? Just another thought...all input would help. Thanks.
Old Apr 20, 2008 | 01:38 PM
heltzelfitness's Avatar
+1
transfer case... you might wanna try and flush the transfer case... if you can. that might save it... but if you had metal shavings in the fluid at the time of the clutch change could also cause the issue too
