walbro vs. factory fuel pump
Is there an easy way to tell if the factory fuel pump has been changed to a 255L when you remove the cover plate under the rear seat without completely removing the pump? (ie. different colored plug, etc.)
lets say that the pump was installed already when I bought the car... i just want to make sure that it is the Walbro before I get tuned or else I want to replace it this next week. I was told that there was a 255l was installed at one point, I just want to make sure it's still in there.
I can tell you that if it's the stock one, it should have a Mitsu symbol on the top of it under all that dirt and dust.
But re-reading your post i'm thinking you meant you know it's a 255L but you don't know if it's a Walbro
after figuring out that there was no way getting around it, I pulled it. The walbro is in there. Definately no whine on this one, so I am ready to get my tune next weekend! TTP Engineering did my first email reflash and a good one at that at the time, but now with the FPgreen, 780cc inj, and alky kit, it's time to step it up a notch!
A quick mod list:
FP EvoGreen Turbo w/upgraded Wastegate
Megan Racing TBE
Injen hard Upper and Lower IP and Intake (K&N Filter)
Turbosmart dual port BOV
Hallman PRO RX MBC
ACT MB7 HDSS Clutch
Walbro 255l Pump
780cc PTE injectors
SMC/Buschur Alky Injection kit w/M10 nozzle
GSC 272i/264e cams
NGK BP7ES plugs, Have BP8ES plugs avail.
AEM UEGO wideband AFR
GReddy TT
Should be a fun car!
A quick mod list:
Megan Racing TBE
Hallman PRO RX MBC
ACT MB7 HDSS Clutch
Walbro 255l Pump
780cc PTE injectors
GSC 272i/264e cams
GReddy TT
