Some questions after 3 days of ownership
After a few days and some 100 miles of ownership... I noticed
that 5th gear is a bit difficult to engage.... The distances of
pushing shifter from neutral to left (to get to 1st or 2nd) and
pushing shifter from neutral to right (to get to 5th) are quite
different.... It also require more effort to push the shifter to the
right??? Both sides are the same on my BMW.
Is this "normal"????
Or the tranny just needs some time to break in??
Tried searching.... all I find is "5th gear grind" problems...
Paint code... after washing my car for the first time after delivery..
I found a little scratch on the driver door (about an inch long)...
Where do I find the paint code on the car??
edit: Found it!!
https://www.evolutionm.net/forums/sh...ght=paint+code
Brakes... They do not seem to bite as good as I expect from a
4 pistons Brembos... Manual says to take it easy for the first
200 miles.... I hope that the performance will improve dramatically
THANK YOU!!
edit: Found it!!
THANK YOU!!
Hi,
Regarding the brakes, I found that they did in fact get better. I was a little disappointed since I expected my eyeballs to hit the windshield.
One thing I've decided is that the brakes don't have tons of initial "bite" like german cars seem to. For example, my Dad's C4s and my old Audi seemed to grab more initially. However, the EVO brakes have a lot of feedback, and the harder you push on the pedal, the harder the car stops.
Try it once you've broken them in and you'll see that you can get a certain amount of braking force, but if you really stomp harder on the brakes, the car will stop a proportional amount harder. It takes getting used to, like I wasn't getting on the brakes hard enough if I needed to brake suddenly, but you get used to it and learn to appreciate it.
Is there not a lot of brake assist or am I just making stuff up?
Thoughts?
FB
Thoughts?
FB
The worries you have are warranted...
The tranny...yes, it took a bit for me to get used to the 4th to 5th shift...you'll get used to it.
Brakes...again...gotta let those *****'s break in...just be easy on 'em. They didn't 'bite' the way I expected either, but every day, they get better...I've only got 550miles on mine and they're good to go!
Enjoy!
Enjoy!
DUDE.....dont worry man ure driving an evo!!!...the brakes feel soft not like they bite right away because they are sport brakes let them break in dude!!....give it like 200 miles and they will stop on a dime trust me. About 5th gear it should not grind talk to the dealer about that. Ive heard probs with 2nd gear grinding because of shifting to fast. Thats about it. And u seemed to find the paint code so good luck with that dude. Trust me evo brakes are good....60-0 in 106 feet is good enough for me.
Originally posted by berkel
Hi,
FB
Hi,
FB
The thing with both of these cars is that they require much more (stomp) force than say a WRX to generate similar stopping force. I find that this is similar to a purpose built race car such as the Panoz GT-RA.
Look real close at the pattern of wear on the front discs. You may notice an uneven pattern from inside to outside, which would indicate the pads are not completely flat and straight when they clamp down. This will eventually disappear as the high spots on the pads wear down. It took damn near 1,000 miles before my brakes achieved maximum performance.
Hi,
Thoughts?
FB
Hi,
Thoughts?
FB
Although I am still not convinced they are as good as the M brakes, I have over time found that they are extremely strong and as mentioned just require a different pedal effort and getting used to the progressive modulation technique.
Jeff
FWIW, the stock brake pads are pretty miserable during hard driving. By hard driving, I mean hard, repeated braking. I can usually get them to smoke visibly after one or two 80-0 brakes. Not something that most do on a daily driving basis. But the few crazies out there will want something more aggressive. We're running Ferrodo high-perf street pads in our EVOs and find them to fit the bill quite nicely. Barely noisier than stock with good cold stopping capabilities. And far more resistant to brake fade.
My 2c,
Shiv
My 2c,
Shiv
Originally posted by shiv@vishnu
FWIW, the stock brake pads are pretty miserable during hard driving. We're running Ferrodo high-perf street pads in our EVOs and find them to fit the bill quite nicely. Barely noisier than stock with good cold stopping capabilities. And far more resistant to brake fade.
My 2c,
Shiv
My 2c,
Shiv
Shiv are you running the ds2500 or ds3000 compound?
Another quick question guys!!..
Does your EVO's engine ticks/taps at idle??
That's usually a sign of low oil level for my M3... just wondering
if that's normal for EVOs..
(That reminds me to check the oil level)
